thinkgeo.mapsuite.wpfdesktopedition.featurerotatingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs
Provides data for the FeatureRotating. event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs
FeatureRotatingEditInteractiveOverlayEventArgs()
  • Constructor of FeatureRotatingEditInteractiveOverlayEventArgs class.
FeatureRotatingEditInteractiveOverlayEventArgs(Feature,Boolean,PointShape,PointShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#FeatureRotatingEditInteractiveOverlayEventArgs.28Feature.2C_Boolean.2C_PointShape.2C_PointShape.29
  • rotatingFeature
    • Type:Feature
    • Description:This parameter specified the target feature to be rotated.
  • cancel
  • sourceControlPoint
    • Description:This parameter specified the source control point to be roated.
  • targetControlPoint
    • Description:This parameter specified the target control point to be roated.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
RotatingFeature
Gets or sets the Feature to be roated.
SourceControlPoint
Gets or sets the source control point to roate.
TargetControlPoint
Gets or sets the target control point to roate.
Cancel
Gets or sets the action to be canceled or not.
thinkgeo.mapsuite.wpfdesktopedition.featurerotatingeditinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
