thinkgeo.mapsuite.wpfdesktopedition.controlpointselectededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectedEditInteractiveOverlayEventArgs
Provides data for the ControlPointSelected event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectedEditInteractiveOverlayEventArgs
ControlPointSelectedEditInteractiveOverlayEventArgs()
  • Constructor of ControlPointSelectedEditInteractiveOverlayEventArgs class.
ControlPointSelectedEditInteractiveOverlayEventArgs(Feature)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectedEditInteractiveOverlayEventArgs#ControlPointSelectedEditInteractiveOverlayEventArgs.28Feature.29
  • selectedFeature
    • Type:Feature
    • Description:This parameter specified the feature selected.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectedEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectedEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectedEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectedEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectedEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectedEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
SelectedFeature
Gets or sets the selected feature.
thinkgeo.mapsuite.wpfdesktopedition.controlpointselectededitinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
