thinkgeo.mapsuite.wpfdesktopedition.interactiveresult
ThinkGeo.MapSuite.WpfDesktopEdition.InteractiveResult
This class specifies the InterativeResult when deal with the Interative method in InterativeOverlay.
    • ThinkGeo.MapSuite.WpfDesktopEdition.InteractiveResult
InteractiveResult()
  • Constructor of InteractiveResult class.
InteractiveResult(InteractiveOverlayDrawType,ProcessOtherOverlaysMode)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractiveResult#InteractiveResult.28InteractiveOverlayDrawType.2C_ProcessOtherOverlaysMode.29
  • interactiveOverlayDrawType
  • processOtherOverlays
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractiveResult#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractiveResult#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractiveResult#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractiveResult#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractiveResult#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.InteractiveResult#MemberwiseClone.28.29
DrawThisOverlay
Gets or sets the DrawThisOverlay type to indicicate to draw this overlay or not.
Gets or sets the DrawThisOverlay type to indicicate how to process other overlays.
NewCurrentExtent
Gets or sets the new current extent if the interative action affect the extent.
thinkgeo.mapsuite.wpfdesktopedition.interactiveresult.txt · Last modified: 2017/03/16 21:59 (external edit)
