thinkgeo.mapsuite.wpfdesktopedition.processotheroverlaysmode
ThinkGeo.MapSuite.WpfDesktopEdition.ProcessOtherOverlaysMode
This enumeration specifies the mode to process other overlays when doing interactive actions with InterativeOverlay.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ProcessOtherOverlaysMode
Items
  • Summary:This enumeration item means that other overlays will still be excuted.
DoNotProcessOtherOverlays
  • Summary:This enumeration item means that other overlays will be ignored.
Default
  • Summary:Default value of the enumation, the same as ProcessOtherOverlays.
thinkgeo.mapsuite.wpfdesktopedition.processotheroverlaysmode.txt · Last modified: 2017/03/16 21:59 (external edit)
