thinkgeo.mapsuite.wpfdesktopedition.featurerotatededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs
Provides data for the FeatureRotated. event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs
FeatureRotatedEditInteractiveOverlayEventArgs()
  • Constructor of FeatureRotatedEditInteractiveOverlayEventArgs class.
FeatureRotatedEditInteractiveOverlayEventArgs(Feature)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs#FeatureRotatedEditInteractiveOverlayEventArgs.28Feature.29
  • rotatedFeature
    • Type:Feature
    • Description:This parameter specified the feature rotated.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureRotatedEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
RotatedFeature
Gets or sets the Feature rotated.
thinkgeo.mapsuite.wpfdesktopedition.featurerotatededitinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
