thinkgeo.mapsuite.wpfdesktopedition.featuredraggingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.FeatureDraggingEditInteractiveOverlayEventArgs
Provides data for the FeatureDragging. event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.FeatureDraggingEditInteractiveOverlayEventArgs
FeatureDraggingEditInteractiveOverlayEventArgs()
  • Constructor of FeatureDraggingEditInteractiveOverlayEventArgs class.
FeatureDraggingEditInteractiveOverlayEventArgs(Feature,Boolean,PointShape,PointShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureDraggingEditInteractiveOverlayEventArgs#FeatureDraggingEditInteractiveOverlayEventArgs.28Feature.2C_Boolean.2C_PointShape.2C_PointShape.29
  • draggingFeature
    • Type:Feature
    • Description:This parameter specified the target feature to be dragged.
  • cancel
  • sourceControlPoint
    • Description:This parameter specified the source control point to be dragged.
  • targetControlPoint
    • Description:This parameter specified the target control point to be dragged.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureDraggingEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureDraggingEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureDraggingEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureDraggingEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureDraggingEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureDraggingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
DraggingFeature
Gets or sets the Feature to be dragged.
SourceControlPoint
Gets or sets the source control point to drag.
TargetControlPoint
Gets or sets the target control point to drag.
Cancel
Gets or sets the action to be canceled or not.
thinkgeo.mapsuite.wpfdesktopedition.featuredraggingeditinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
