thinkgeo.mapsuite.wpfdesktopedition.keyeventinteractionarguments
ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments
Represents key event arguments when interacting with the map object.
    • ThinkGeo.MapSuite.WpfDesktopEdition.KeyEventInteractionArguments
KeyEventInteractionArguments()
Constructor of KeyEventInteractionArguments class.
If you use this constructor, you have to set its properties manually before use.
KeyEventInteractionArguments(String,Boolean,Boolean,Boolean)
This is the constructor of this parameter by passing parameters.
  • key
    • Description:This parameters indicates the key string used in the events.
  • isCtrlKeyPressed
    • Description:This parameter indicates the CTRIL key is pressed or not.
  • isShiftKeyPressed
    • Description:This parameter indicates the SHIFT key is pressed or not.
  • isAltKeyPressed
    • Description:This parameter indicates the ALT key is pressed or not.
Key
This property gets string indicates the key used in the key events.
IsCtrlKeyPressed
Gets a value indicating whether the CTRL key was pressed. true if the CTRL key was pressed; otherwise, false.
IsShiftKeyPressed
Gets a value indicating whether the SHIFT key was pressed. true if the SHIFT key was pressed; otherwise, false.
IsAltKeyPressed
Gets a value indicating whether the ALT key was pressed. true if the ALT key was pressed; otherwise, false.
CurrentExtent
Gets or sets the current extent used in the MapControl.
CurrentScale
Gets or sets the scale in the current status.
thinkgeo.mapsuite.wpfdesktopedition.keyeventinteractionarguments.txt · Last modified: 2017/03/16 21:59 (external edit)
