thinkgeo.mapsuite.wpfdesktopedition.maparguments
ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments
Contains important properties and methods of current map object.
    • ThinkGeo.MapSuite.WpfDesktopEdition.MapArguments
MapArguments()
Constructor of MapArguments.
ToWorldCoordinate(PointShape)
Converts a point from screen coordinate to world coordinate.
  • Description:A point in world coordinate.
  • screenCoordinate
    • Description:A point in screen coordinate to be converted.
ToScreenCoordinate(PointShape)
Converts a point from world coordinate to screen coordinate.
  • Description:A point in screen coordinate.
  • worldCoordinate
    • Description:A point in world coordinate to be converted.
GetSnappedZoomLevelIndex(RectangleShape)
Gets a snapped zoom level index from the provided extent.
The extent will automatically snapped a closest scale from the ZoomLevelScale list, and create an extent back with the map's screen width and height.
  • Description:An integar value that indicates the snapped zoom level index.
GetSnappedZoomLevelIndex(Double)
Gets a snapped zoom level index from the provided scale.
The scale will automatically snapped a closest scale from the ZoomLevelScale list, and create an extent back with the map's screen width and height.
  • scale
    • Description:A scale to be snapped.
GetSnappedExtent(RectangleShape)
Gets a snapped extent from the provided extent.
  • Description:A RectangleShape object that indicates the extent which is snapped.
GetSnappedExtent(RectangleShape,ZoomSnapDirection)
MapUnit
Gets or sets the GeographyUnit for the map.
ActualWidth
Gets or sets the width of current map object in screen coordinate.
ActualHeight
Gets or sets the height of current map object in screen coordinate.
ZoomLevelScales
Gets a collection of double values that determines the zoomlevel scales.
  • Type:Collection<Double>
CurrentResolution
Gets or sets a double value that indicates the current resolution of the map.
CurrentScale
Gets or sets a double value that indicates the current scale of the map.
MaximumScale
This property gets and sets a maximum scale when navigating the map. When you keep zooming out, and the target scale is bigger than the maximum scale, the zooming operation will be stopped.
MinimumScale
This property gets and sets a minimum scale when navigating the map. When you keep zooming in, and the target scale is smaller than the minimum scale, the zooming operation will be stopped.
CurrentExtent
Gets or sets the extent of current map.
MaxExtent
Gets or sets the max extent of current map.
thinkgeo.mapsuite.wpfdesktopedition.maparguments.txt · Last modified: 2017/03/16 21:59 (external edit)
