thinkgeo.mapsuite.wpfdesktopedition.mapmousewheelinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseWheelInteractiveOverlayEventArgs
Provides data for the MapMouseWheel event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseWheelInteractiveOverlayEventArgs
MapMouseWheelInteractiveOverlayEventArgs()
  • Constructor of MapMouseWheelInteractiveOverlayEventArgs class.
MapMouseWheelInteractiveOverlayEventArgs(InteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseWheelInteractiveOverlayEventArgs#MapMouseWheelInteractiveOverlayEventArgs.28InteractionArguments.29
  • interactionArguments
    • Description:This parameter specified the interaction auguments to construct the class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseWheelInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseWheelInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseWheelInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseWheelInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseWheelInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseWheelInteractiveOverlayEventArgs#MemberwiseClone.28.29
This property gets the interaction auguments for the event args.
thinkgeo.mapsuite.wpfdesktopedition.mapmousewheelinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
