thinkgeo.mapsuite.wpfdesktopedition.vertexmovededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovedEditInteractiveOverlayEventArgs
Provides data for the VertexMoved. event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovedEditInteractiveOverlayEventArgs
VertexMovedEditInteractiveOverlayEventArgs()
  • Constructor of VertexMovedEditInteractiveOverlayEventArgs class.
VertexMovedEditInteractiveOverlayEventArgs(Feature,Vertex)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovedEditInteractiveOverlayEventArgs#VertexMovedEditInteractiveOverlayEventArgs.28Feature.2C_Vertex.29
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • movedVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex moved.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovedEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovedEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovedEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovedEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovedEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovedEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
AffectedVertexFeature
Gets or sets the Feature to be used to remove vertex.
MovedVertex
Gets or sets the vertex moved.
thinkgeo.mapsuite.wpfdesktopedition.vertexmovededitinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
