thinkgeo.mapsuite.windowsphonecore.nativeimagetilecache
ThinkGeo.MapSuite.WindowsPhoneCore.NativeImageTileCache
<!– Class –> This is the base class for NativeTileCache system which inherits from TileCache class.
TileCahce system is very efficient in improving the performance of application, especially when large data or remote server images are included.
Protected MethodNativeImageTileCache String, TileMatrix This is the constructor of the class.
Public MethodClearCache TileCache This method will clear all the tiles in the tileCache.
Public MethodDeleteTile Tile TileCache This method will delete the target tile passed in.
Public MethodGetTile RectangleShape This method returns the NativeImageTile corresponding to the tile bounding box passed in.
Public MethodGetTile Int64, Int64 This method returns the NativeImageTile corresponding to passed in row and column.
Public MethodGetTiles RectangleShape This method returns all the NativeImageTiles within the passed in world extent.
Public MethodGetType Object
Public MethodSaveTile Tile TileCache This method will save the target tile passed in.
Public MethodToString Object
Protected MethodClearCacheCore TileCache This abstract method will clear all the tiles in the tileCache, for each sub TileCache class must implement this method.
Protected MethodDeleteTileCore Tile TileCache This abstract method will delete the target tile passed in, for each sub TileCache class must implement this method.
Protected MethodGetTileCore Int64, Int64 This abstract method returns the NativeImageTile corresponding to passed in row and column. Each concrete TileCache need to implement this logic to get tile from a row and column.
Protected MethodSaveTileCore Tile TileCache This abstract method will save the target tile passed in, for each sub TileCache class must implement this method.
Public PropertyCacheId String TileCache Gets or sets the id of the TileCache.
Public PropertyTileAccessMode TileAccessMode TileCache Gets or sets the Mode for the TileCache access the tiles. The Default value is ReadAddDelete
Public PropertyTileMatrix TileMatrix TileCache Gets or sets the TileMatrix which is used in caculation for tiles.
NativeImageTileCache(String, TileMatrix)
Name Type Description
cacheId String<!– System.String –> This is the cache identifier which marks its difference with other TileCache.
tileMatrix TileMatrix<!– ThinkGeo.MapSuite.WindowsPhoneCore.TileMatrix –> This is the tile matrix system which is used for caculating tiles.
Go Back
ClearCache()
This method will not take effect when the ReadOnly is set to true.
Return Type Description
Void<!– System.Void –>
<!– ThinkGeo.MapSuite.WindowsPhoneCore.TileCache –> Go Back
DeleteTile(Tile)
tile Tile<!– ThinkGeo.MapSuite.WindowsPhoneCore.Tile –> The target tile to be deleted.
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetTile(RectangleShape)
NativeImageTile<!– ThinkGeo.MapSuite.WindowsPhoneCore.NativeImageTile –> Returns the NativeImageTile corresponding to the passed in boundingBox.
tileBoundingBox RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> The target boundingBox for the tile to fetch.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.NativeImageTileCache –> Go Back
GetTile(Int64, Int64)
NativeImageTile<!– ThinkGeo.MapSuite.WindowsPhoneCore.NativeImageTile –> Returns the NativeImageTile corresponding to the passed in row and column.
row Int64<!– System.Int64 –> The target row for the tile to fetch.
column Int64<!– System.Int64 –> The target column for the tile to fetch.
GetTiles(RectangleShape)
Collection<NativeImageTile><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.NativeImageTile} –> Returns a collection of NativeImageTiles within the passed in worldExtent.
extent RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> The target worldExtent will be used to fetch all the NativeImageTiles from.
Type<!– System.Type –>
SaveTile(Tile)
tile Tile<!– ThinkGeo.MapSuite.WindowsPhoneCore.Tile –> The target tile to be saved.
ClearCacheCore()
DeleteTileCore(Tile)
GetTileCore(Int64, Int64)
SaveTileCore(Tile)
CacheId
Return Type
TileAccessMode
If you want it to take effect, you need set the ReadOnly property false.
Return Type
TileAccessMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.TileAccessMode –>
TileMatrix
Return Type
thinkgeo.mapsuite.windowsphonecore.nativeimagetilecache.txt · Last modified: 2017/03/16 21:59 (external edit)
