thinkgeo.mapsuite.windowsphonecore.nativeimagetile
ThinkGeo.MapSuite.WindowsPhoneCore.NativeImageTile
<!– Class –> This class represents a NativeImageTile, which is defined as scale, RectangleBox and a byte array for its tile bitmap.
Public MethodNativeImageTile This is the default constructor without passing any parameters. All its properties should be set via the properties.
Public MethodNativeImageTile RectangleShape, Double This is the constructor for Tile by passing the boundingBox and scale.
Public MethodNativeImageTile Byte[], RectangleShape, Double This is the constructor for Tile by passing image bitmap array and the boundingBox and scale.
Public MethodGetType Object
Public MethodToString Object
Public PropertyBoundingBox RectangleShape Tile The Bounding box to describe the Tile.
Public PropertyNativeImage Byte[] This property is the byte arry showing the image of the tile.
Public PropertyScale Double Tile The scale to describe the Tile.
NativeImageTile()
Name Type Description
Go Back
NativeImageTile(RectangleShape, Double)
boundingBox RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –>
scale Double<!– System.Double –>
Go Back
NativeImageTile(Byte[], RectangleShape, Double)
nativeImage Byte[]<!– System.Bytethinkgeo.mapsuite.windowsphonecore.nativeimagetile –>
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
BoundingBox
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Tile –> Go Back
NativeImage
Return Type
<!– ThinkGeo.MapSuite.WindowsPhoneCore.NativeImageTile –> Go Back
Scale
Return Type
thinkgeo.mapsuite.windowsphonecore.nativeimagetile.txt · Last modified: 2017/03/16 21:59 (external edit)
