thinkgeo.mapsuite.windowsphonecore.pointplacement
ThinkGeo.MapSuite.WindowsPhoneCore.PointPlacement
<!– Enumeration –> This enumeration determines the label placement when labeling point features.
Items
Name Summary
UpperLeft The label will be placed in the upper left, in relation to the point.
UpperCenter The label will be placed in the upper center, in relation to the point.
UpperRight The label will be placed in the upper right, in relation to the point.
CenterRight The label will be placed in the center right, in relation to the point.
Center The label will be placed in the center, in relation to the point.
CenterLeft The label will be placed in the center left, in relation to the point.
LowerLeft The label will be placed in the lower left, in relation to the point.
LowerCenter The label will be placed in the lower center, in relation to the point.
LowerRight The label will be placed in the lower right, in relation to the point.
thinkgeo.mapsuite.windowsphonecore.pointplacement.txt · Last modified: 2017/03/16 21:59 (external edit)
