<!– Class –> This class is a concrete class inherits from NativeImageTileCache. In this class, the tiles will be saved in disk and can be viewed very conveniently.
*System.Object ThinkGeo.MapSuite.WindowsPhoneCore.TileCache *ThinkGeo.MapSuite.WindowsPhoneCore.NativeImageTileCache ThinkGeo.MapSuite.WindowsPhoneCore.IsolatedStorageFileNativeImageTileCache
IsolatedStorageFileNativeImageTileCache | This is the default constructor. | ||
IsolatedStorageFileNativeImageTileCache | String, String, TileMatrix | This is the constructor with all the parameters needed passed in. |
ClearCache | TileCache | This method will clear all the tiles in the tileCache. | |
DeleteTile | Tile | TileCache | This method will delete the target tile passed in. |
GetTile | RectangleShape | NativeImageTileCache | This method returns the NativeImageTile corresponding to the tile bounding box passed in. |
GetTile | Int64, Int64 | NativeImageTileCache | This method returns the NativeImageTile corresponding to passed in row and column. |
GetTiles | RectangleShape | NativeImageTileCache | This method returns all the NativeImageTiles within the passed in world extent. |
SaveTile | Tile | TileCache | This method will save the target tile passed in. |
ClearCacheCore | TileCache(overriden) | This method will clear all the tiles in the tileCache. | |
DeleteTileCore | Tile | TileCache(overriden) | This method will delete the target tile passed in. |
GetTileCore | Int64, Int64 | NativeImageTileCache(overriden) | This method returns the NativeImageTile corresponding to passed in row and column. |
MemberwiseClone | Object | ||
SaveTileCore | Tile | TileCache(overriden) | This method will save the target tile passed in, you could override this API to create your own logic. |
CacheId | String | TileCache | Gets or sets the id of the TileCache. |
DirectoryName | String | Gets or sets the cache direcory. | |
MaxCacheSize | Int64 | ||
TileAccessMode | TileAccessMode | TileCache | Gets or sets the Mode for the TileCache access the tiles. The Default value is ReadAddDelete |
TileMatrix | TileMatrix | TileCache | Gets or sets the TileMatrix which is used in caculation for tiles. |
If you use this constructor, you have to set the properties manually.
| directoryName | String<!– System.String –> | This parameter specifies the cache directory of the tile cache. |
| cacheId | String<!– System.String –> | This parameter specifies the cache id of the tile cache. |
| tileMatrix | TileMatrix<!– ThinkGeo.MapSuite.WindowsPhoneCore.TileMatrix –> | This parameter specifies the tile matrix of the tile cache. |
This method will not take effect when the ReadOnly is set to true.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.TileCache –> Go Back
| tile | Tile<!– ThinkGeo.MapSuite.WindowsPhoneCore.Tile –> | The target tile to be deleted. |
| NativeImageTile<!– ThinkGeo.MapSuite.WindowsPhoneCore.NativeImageTile –> | Returns the NativeImageTile corresponding to the passed in boundingBox. |
| tileBoundingBox | RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> | The target boundingBox for the tile to fetch. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.NativeImageTileCache –> Go Back
| NativeImageTile<!– ThinkGeo.MapSuite.WindowsPhoneCore.NativeImageTile –> | Returns the NativeImageTile corresponding to the passed in row and column. |
| row | Int64<!– System.Int64 –> | The target row for the tile to fetch. |
| column | Int64<!– System.Int64 –> | The target column for the tile to fetch. |
| Collection<NativeImageTile><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.NativeImageTile} –> | Returns a collection of NativeImageTiles within the passed in worldExtent. |
| extent | RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> | The target worldExtent will be used to fetch all the NativeImageTiles from. |
| tile | Tile<!– ThinkGeo.MapSuite.WindowsPhoneCore.Tile –> | The target tile to be saved. |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.TileCache(overriden) –> Go Back
<!– ThinkGeo.MapSuite.WindowsPhoneCore.NativeImageTileCache(overriden) –> Go Back
<!– ThinkGeo.MapSuite.WindowsPhoneCore.IsolatedStorageFileNativeImageTileCache –> Go Back
If you want it to take effect, you need set the ReadOnly property false.
| TileAccessMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.TileAccessMode –> |
