<!– Class –> This is the base class for TileCache system.
TileCahce system is very efficient in improving the performance of application, especially when large data or remote server images are included.
*System.Object ThinkGeo.MapSuite.WindowsPhoneCore.TileCache *ThinkGeo.MapSuite.WindowsPhoneCore.IsolatedStorageFileNativeImageTileCache ***ThinkGeo.MapSuite.WindowsPhoneCore.NativeImageTileCache
|  TileCache | String, TileMatrix | This is the constructor of the class. |
|  ClearCache | This method will clear all the tiles in the tileCache. | ||
|  DeleteTile | Tile | This method will delete the target tile passed in. | |
|  Equals | Object | Object | |
|  GetHashCode | Object | ||
|  GetType | Object | ||
|  SaveTile | Tile | This method will save the target tile passed in. | |
|  ToString | Object |
|  ClearCacheCore | This abstract method will clear all the tiles in the tileCache, for each sub TileCache class must implement this method. | ||
|  DeleteTileCore | Tile | This abstract method will delete the target tile passed in, for each sub TileCache class must implement this method. | |
|  Finalize | Object | ||
|  MemberwiseClone | Object | ||
|  SaveTileCore | Tile | This abstract method will save the target tile passed in, for each sub TileCache class must implement this method. |
|  CacheId | String | Gets or sets the id of the TileCache. | |
|  TileAccessMode | TileAccessMode | Gets or sets the Mode for the TileCache access the tiles. The Default value is ReadAddDelete | |
|  TileMatrix | TileMatrix | Gets or sets the TileMatrix which is used in caculation for tiles. |
| cacheId | String<!– System.String –> | This is the cache identifier which marks its difference with other TileCache. |
| tileMatrix | TileMatrix<!– ThinkGeo.MapSuite.WindowsPhoneCore.TileMatrix –> | This is the tile matrix system which is used for caculating tiles. |
This method will not take effect when the ReadOnly is set to true.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.TileCache –> Go Back
| tile | Tile<!– ThinkGeo.MapSuite.WindowsPhoneCore.Tile –> | The target tile to be deleted. |
| tile | Tile<!– ThinkGeo.MapSuite.WindowsPhoneCore.Tile –> | The target tile to be saved. |
If you want it to take effect, you need set the ReadOnly property false.
| TileAccessMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.TileAccessMode –> |
