thinkgeo.mapsuite.wpfdesktopedition.featureresizingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs
Provides data for the FeatureResizing. event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs
FeatureResizingEditInteractiveOverlayEventArgs()
  • Constructor of FeatureResizingEditInteractiveOverlayEventArgs class.
FeatureResizingEditInteractiveOverlayEventArgs(Feature,Boolean,PointShape,PointShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#FeatureResizingEditInteractiveOverlayEventArgs.28Feature.2C_Boolean.2C_PointShape.2C_PointShape.29
  • resizingFeature
    • Type:Feature
    • Description:This parameter specified the target feature to be resized.
  • cancel
  • sourceControlPoint
    • Description:This parameter specified the source control point to be resized.
  • targetControlPoint
    • Description:This parameter specified the target control point to be resized.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.FeatureResizingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
ResizingFeature
Gets or sets the Feature to be resized.
SourceControlPoint
Gets or sets the source control point to be resized.
TargetControlPoint
Gets or sets the target control point to be resized.
Cancel
Gets or sets the action to be canceled or not.
thinkgeo.mapsuite.wpfdesktopedition.featureresizingeditinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
