thinkgeo.mapsuite.wpfdesktopedition.vertexremovingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs
Provides data for the VertexRemoving. event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs
VertexRemovingEditInteractiveOverlayEventArgs()
  • Constructor of VertexRemovingEditInteractiveOverlayEventArgs class.
VertexRemovingEditInteractiveOverlayEventArgs(Boolean,Feature,Vertex)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#VertexRemovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.29
  • cancel
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • removingVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex to be removed.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
AffectedVertexFeature
Gets or sets the Feature to be used to remove vertex.
RemovingVertex
Gets or sets the vertex to be removed.
Cancel
Gets or sets the action to be canceled or not.
thinkgeo.mapsuite.wpfdesktopedition.vertexremovingeditinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
