thinkgeo.mapsuite.wpfdesktopedition.featureresizededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.FeatureResizedEditInteractiveOverlayEventArgs
Provides data for the FeatureResized. event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.FeatureResizedEditInteractiveOverlayEventArgs
FeatureResizedEditInteractiveOverlayEventArgs()
Constructor of FeatureResizedEditInteractiveOverlayEventArgs class.
FeatureResizedEditInteractiveOverlayEventArgs(Feature)
  • resizedFeature
    • Type:Feature
    • Description:This parameter specified the feature resized.
ResizedFeature
Gets or sets the Feature resized.
thinkgeo.mapsuite.wpfdesktopedition.featureresizededitinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
