thinkgeo.mapsuite.wpfdesktopedition.mapmouseenterinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseEnterInteractiveOverlayEventArgs
Provides data for the MapMouseUp event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseEnterInteractiveOverlayEventArgs
MapMouseEnterInteractiveOverlayEventArgs()
Constructor of MapMouseEnterInteractiveOverlayEventArgs class.
MapMouseEnterInteractiveOverlayEventArgs(InteractionArguments)
  • interactionArguments
    • Description:This parameter specified the interaction auguments to construct the class.
This property gets the interaction auguments for the event args.
thinkgeo.mapsuite.wpfdesktopedition.mapmouseenterinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
