thinkgeo.mapsuite.wpfdesktopedition.drawingoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs
This is the event arguments for the OverlayDrawing event on the MapEngine class. It is raised before the Overlay is drawn.
      • ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs
DrawingOverlayEventArgs()
  • Constructor of DrawingOverlayEventArgs class.
  • This is the default constructor. If you use this constructor then you need to set the required properties manually.
DrawingOverlayEventArgs(RectangleShape,Boolean)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#DrawingOverlayEventArgs.28RectangleShape.2C_Boolean.29
  • worldExtent
    • Description:This parameter is the extent for drawing an overlay.
  • cancel
    • Description:This parameter indicates whether cancel current drawing process.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#MemberwiseClone.28.29
WorldExtent
Gets or sets an extent to draw the overlay.
Cancel
Gets or sets a value that determines whether you want to cancel the Overlay from drawing.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawingOverlayEventArgs#Cancel
thinkgeo.mapsuite.wpfdesktopedition.drawingoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
