thinkgeo.mapsuite.mvcedition.cloudpopupsetting
ThinkGeo.MapSuite.MvcEdition.CloudPopupSetting
A setting for CloudPopup that contains APIs to set properties of CloudPopupSetting using in MVC view.
CloudPopupSetting(CloudPopup)
  • Initializes a new instance of the CloudPopupSetting class.
ContentHtml(String)
  • Set contentHtml for Element property and retun the CloudPopupSetting
  • contentHtml
    • Description:A contentHtml for Element property
Position(PointShape)
Width(Int32)
  • width
Height(Int32)
  • height
IsVisible(Boolean)
  • isVisible
Opacity(Single)
  • opacity
    • Type:Single
AutoSize(Boolean)
  • autoSize
AutoPan(Boolean)
  • autoPan
HasCloseButton(Boolean)
  • hasCloseButton
OffsetXInPixels(Int32)
  • offsetXInPixels
OffsetYInPixels(Int32)
  • offsetYInPixels
Element
thinkgeo.mapsuite.mvcedition.cloudpopupsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
