thinkgeo.mapsuite.mvcedition.featureoverlaystylesetting
ThinkGeo.MapSuite.MvcEdition.FeatureOverlayStyleSetting
A setting for FeatureOverlayStyle that contains APIs to set properties of FeatureOverlayStyleSetting using in MVC view.
FeatureOverlayStyleSetting(FeatureOverlayStyle)
  • Initializes a new instance of the FeatureOverlayStyleSetting class.
  • featureOverlayStyle
    • Description:the FeatureOverlay Style which will be assigned to Element property
FillColor(GeoColor)
  • Set fillColor for Element property and retun the FeatureOverlayStyleSetting
  • fillColor
    • Type:GeoColor
    • Description:A fillColor for Element property
OutlineColor(GeoColor)
  • Set outlineColor for Element property and retun the FeatureOverlayStyleSetting
  • outlineColor
    • Type:GeoColor
    • Description:A outlineColor for Element property
OutlineWidth(Int32)
  • Set outlineWidth for Element property and retun the FeatureOverlayStyleSetting
  • outlineWidth
    • Description:A outlineWidth for Element property
Element
thinkgeo.mapsuite.mvcedition.featureoverlaystylesetting.txt · Last modified: 2017/03/16 21:59 (external edit)
