thinkgeo.mapsuite.mvcedition.panzoombarmaptoolsetting
ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapToolSetting
A setting for PanZoomBarMapTool that contains APIs to set properties of PanZoomBarMapToolSetting using in MVC view.
PanZoomBarMapToolSetting(PanZoomBarMapTool)
  • Initializes a new instance of the PanZoomBarMapToolSetting class.
IsGlobeButtonEnabled(Boolean)
  • Set isGlobeButtonEnabled for Element property and retun the PanZoomBarMapToolSetting
  • isGlobeButtonEnabled
    • Description:A isGlobeButtonEnabled for Element property
Enabled(Boolean)
  • isEnabled
Element
thinkgeo.mapsuite.mvcedition.panzoombarmaptoolsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
