thinkgeo.mapsuite.desktopedition.overlaylock
ThinkGeo.MapSuite.DesktopEdition.OverlayLock
This class defines a lock that supports a single writer and multiple readers.
    • ThinkGeo.MapSuite.DesktopEdition.OverlayLock
OverlayLock()
  • Default constructor of this class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayLock#OverlayLock.28.29
EnterReadLock()
  • Enter the read lock immediately.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayLock#EnterReadLock.28.29
EnterWriteLock()
  • Enter the write lock immediately.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayLock#EnterWriteLock.28.29
ExitReadLock()
  • Exit the read lock immediately.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayLock#ExitReadLock.28.29
ExitWriteLock()
  • Exit the write lock immediately.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayLock#ExitWriteLock.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayLock#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayLock#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayLock#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayLock#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayLock#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.OverlayLock#MemberwiseClone.28.29
IsDirty
  • This property can be used to mark the Overlay “dirty,” which indicates that its data has changed.
thinkgeo.mapsuite.desktopedition.overlaylock.txt · Last modified: 2017/03/16 21:59 (external edit)
