thinkgeo.mapsuite.mvcedition.mousemaptoolsetting
ThinkGeo.MapSuite.MvcEdition.MouseMapToolSetting
A setting for MouseMapTool that contains APIs to set properties of MouseMapToolSetting using in MVC view.
MouseMapToolSetting(MouseMapTool)
  • Initializes a new instance of the MouseMapToolSetting class.
IsMouseWheelDisabled(Boolean)
  • Set isMouseWheelDisabled for Element property and retun the MouseMapToolSetting
  • isMouseWheelDisabled
    • Description:A isMouseWheelDisabled for Element property
TrackZoomMaskType(TrackZoomMaskType)
  • Set trackZoomMaskType for Element property and retun the MouseMapToolSetting
  • trackZoomMaskType
Enabled(Boolean)
  • isEnabled
Element
thinkgeo.mapsuite.mvcedition.mousemaptoolsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
