thinkgeo.mapsuite.mvcedition.openstreetmapoverlaysetting
ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlaySetting
A setting for OpenStreetMapOverlay that contains APIs to set properties of OpenStreetMapOverlaySetting using in MVC view.
OpenStreetMapOverlaySetting(OpenStreetMapOverlay)
  • Initializes a new instance of the OpenStreetMapOverlaySetting class.
TileWidth(Int32)
  • Set tileWidth for Element property and retun the OpenStreetMapOverlaySetting
  • tileWidth
    • Description:A tileWidth for Element property
TileHeight(Int32)
  • Set tileHeight for Element property and retun the OpenStreetMapOverlaySetting
  • tileHeight
    • Description:A tileHeight for Element property
IsVisible(Boolean)
  • isVisible
Name(String)
  • name
Opacity(Single)
  • opacity
    • Type:Single
IsVisibleInOverlaySwitcher(Boolean)
  • isVisibleInOverlaySwitcher
IsBaseOverlay(Boolean)
  • isBaseOverlay
Id(String)
  • id
OnClientAutoRefreshTick(String)
  • clientTickFunctionName
AutoRefreshInterval(TimeSpan)
  • timeSpan
    • Type:TimeSpan
Element
thinkgeo.mapsuite.mvcedition.openstreetmapoverlaysetting.txt · Last modified: 2017/03/16 21:59 (external edit)
