Defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
GetMarkers(IEnumerable<Feature>)
Gets or sets the style that is applied to the markers if the CustomMarkerStyle is not defined.
The CustomMarkerStyle has a higher priority than the DefaultMarkerStyle. When you define both styles, the CustomMarkerStyle will be applied. The CustomMarkerStyle can be any kind of MarkerStyle while the DefaultMarkerStyle cannot.
