thinkgeo.mapsuite.mvcedition.pointmarkerstyle
ThinkGeo.MapSuite.MvcEdition.PointMarkerStyle
Represents the ordinary marker style.
    • ThinkGeo.MapSuite.MvcEdition.MarkerStyle
      • ThinkGeo.MapSuite.MvcEdition.PointMarkerStyle
PointMarkerStyle()
  • Initialize an instance of the PointMarkerStyle class.
PointMarkerStyle(WebImage)
  • webImage
    • Type:WebImage
    • Description:The small image that the marker displays.
PointMarkerStyle(WebImage,CustomPopup)
  • webImage
    • Type:WebImage
  • popup
    • Description:The popup window that appears when the mouse pointer is over the marker.
PointMarkerStyle(WebImage,CustomPopup,ContextMenu)
  • webImage
    • Type:WebImage
  • popup
  • contextMenu
    • Description:The context menu that appears when you right-click on the marker.
GetMarkers(IEnumerable<Feature>)
  • Returns a collection of markers that are created with specific styles from the features passed in.
  • Type:Collection<Marker>
  • features
    • Type:IEnumerable<Feature>
    • Description:A collection of features that the markers are created from.
GetContextMenusCore()
  • Gets a collection of context menus that are associated with the MarkerStyle.
LxU=()
Popup
Gets or sets the popup object that displays when the mouse pointer is over a marker.
PopupDelay
Gets or sets a value indicating the interval that should elapse between when the mouse moves over the marker and when its popup window displays.
The PopupDelay value is counted in milliseconds. If it is set to 500, the popup will display 500ms after the mouse pointer hovers over the marker.
WebImage
Gets or sets the small image that the marker displays as its icon.
ContextMenu
Gets or sets a context menu object that displays when you right-click on the marker.
Opacity
Gets or sets a float value between 0 and 1 that indicates the transparency level of the marker.
The Opacity property enables you to specify a level of transparency for the marker. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. Setting this property to a value of 0 percent (0.00) makes the marker completely invisible.
  • Type:Single
thinkgeo.mapsuite.mvcedition.pointmarkerstyle.txt · Last modified: 2017/03/16 21:59 (external edit)
