thinkgeo.mapsuite.mvcedition.inmemorymarkeroverlay
ThinkGeo.MapSuite.MvcEdition.InMemoryMarkerOverlay
Represents a MarkerOverlay object that dynamically creates markers from the InMemory features.
    • ThinkGeo.MapSuite.MvcEdition.Overlay
      • ThinkGeo.MapSuite.MvcEdition.MarkerOverlay
        • ThinkGeo.MapSuite.MvcEdition.InMemoryMarkerOverlay
InMemoryMarkerOverlay()
  • Initialize an instance of the InMemoryMarkerOverlay class.
InMemoryMarkerOverlay(String)
  • id
    • Description:The identifier of the overlay, which is used for retrieving the overlay.
InMemoryMarkerOverlay(String,IEnumerable<String>)
  • id
  • featureColumnNames
    • Type:IEnumerable<String>
    • Description:The column names that are associated with the features in the overlay.
InMemoryMarkerOverlay(String,IEnumerable<FeatureSourceColumn>)
  • id
  • featureColumns
    • Type:IEnumerable<FeatureSourceColumn>
DataBindTo(String,String)
  • controllerName
  • actionName
GetMarkers(RectangleShape,Int32)
  • Type:Collection<Marker>
  • currentZoomLevelId
ToJson()
FromJson(String)
  • jsonString
GetMarkersCore(RectangleShape,Int32)
  • Returns a collection of markers based on the extent and zoomlevel that you passed in.
  • Description:A collection of marker objects that will be serialized to the client.
  • worldExtent
    • Description:The extent that includes all of the markers that you want to serialize.
    • Description:An int value that indicates which zoomlevel the map is currently at.
EhQ=(Page)
  • page
    • Type:Page
  • page
    • Type:Page
Columns
Gets the collection of FeatureSourceColumns that is the column definition of the feature data.
SuppressingGridSize
Gets or sets the grid size in screen coordinate to suppress markers in current Viewport.
Current ViewPort will be split into several cells by FilterGridSize, one cell will contains only one marker in it, in another word, markers which are near too close will be removed. if the value is greater than 0, this function will be enabled.
FeatureSource
Gets a FeatureSource object by which you can perform queries on the features in the overlay.
ZoomLevelSet
Gets the ZoomLevelSet object that controls the markers' generation.
IsBaseOverlay
OnClientClick
OnClientMarkersRequesting
OnClientMarkersRequested
ActionTriggers
IsVisible
Opacity
  • Type:Single
IsVisibleInOverlaySwitcher
Id
OnClientAutoRefreshTick
AutoRefreshInterval
  • Type:TimeSpan
Attribution
OverlayType
IsDefault
TRU=
ERQ=
thinkgeo.mapsuite.mvcedition.inmemorymarkeroverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
