InMemoryFeatureSource(IEnumerable<FeatureSourceColumn>)
InMemoryFeatureSource(IEnumerable<FeatureSourceColumn>,IEnumerable<Feature>)
InMemoryFeatureSource(IEnumerable<FeatureSourceColumn>,IEnumerable<BaseShape>)
GetAllFeatures(IEnumerable<String>)
GetFeaturesOutsideBoundingBox(RectangleShape,IEnumerable<String>)
GetFeaturesOutsideBoundingBox(RectangleShape,ReturningColumnsType)
GetFeaturesInsideBoundingBox(RectangleShape,IEnumerable<String>)
GetFeaturesInsideBoundingBox(RectangleShape,IEnumerable<String>,IEnumerable<String>)
GetFeaturesInsideBoundingBox(RectangleShape,ReturningColumnsType)
GetFeaturesForDrawing(RectangleShape,Double,Double,IEnumerable<String>,IEnumerable<String>)
ApplyFilters(IEnumerable<Feature>,IEnumerable<String>,IEnumerable<String>)
GetFeaturesForDrawing(RectangleShape,Double,Double,IEnumerable<String>)
GetFeaturesForDrawing(RectangleShape,Double,Double,ReturningColumnsType)
SpatialQuery(BaseShape,QueryType,IEnumerable<String>)
SpatialQuery(BaseShape,QueryType,IEnumerable<String>,IEnumerable<String>)
SpatialQuery(BaseShape,QueryType,ReturningColumnsType)
SpatialQuery(Feature,QueryType,IEnumerable<String>)
SpatialQuery(Feature,QueryType,ReturningColumnsType)
GetFeaturesNearestTo(BaseShape,GeographyUnit,Int32,IEnumerable<String>)
GetFeaturesNearestTo(BaseShape,GeographyUnit,Int32,ReturningColumnsType)
GetFeaturesNearestTo(Feature,GeographyUnit,Int32,IEnumerable<String>)
GetFeaturesNearestTo(Feature,GeographyUnit,Int32,ReturningColumnsType)
GetFeaturesNearestTo(BaseShape,GeographyUnit,Int32,IEnumerable<String>,Double,DistanceUnit)
GetFeaturesNearestTo(Feature,GeographyUnit,Int32,IEnumerable<String>,Double,DistanceUnit)
GetFeaturesWithinDistanceOf(BaseShape,GeographyUnit,DistanceUnit,Double,IEnumerable<String>)
GetFeaturesWithinDistanceOf(BaseShape,GeographyUnit,DistanceUnit,Double,ReturningColumnsType)
GetFeaturesWithinDistanceOf(Feature,GeographyUnit,DistanceUnit,Double,IEnumerable<String>)
GetFeaturesWithinDistanceOf(Feature,GeographyUnit,DistanceUnit,Double,ReturningColumnsType)
GetFeatureById(String,IEnumerable<String>)
GetFeatureById(String,ReturningColumnsType)
GetFeaturesByIds(IEnumerable<String>,IEnumerable<String>,IEnumerable<String>)
GetFeaturesByIds(IEnumerable<String>,IEnumerable<String>)
GetFeaturesByIds(IEnumerable<String>,ReturningColumnsType)
GetAllFeatures(ReturningColumnsType,Int32,Int32)
GetAllFeatures(IEnumerable<String>,Int32,Int32)
GetFeaturesByColumnValue(String,String,ReturningColumnsType)
GetFeaturesByColumnValue(String,String,IEnumerable<String>)
GetFeaturesByColumnValue(String,String)
CommitTransactionCore(TransactionBuffer)
GetAllFeaturesCore(IEnumerable<String>)
GetAllFeaturesCore(IEnumerable<String>,Int32,Int32)
GetFeaturesInsideBoundingBoxCore(RectangleShape,IEnumerable<String>)
GetFeaturesInsideBoundingBoxByReference(RectangleShape,IEnumerable<String>)
GetFeaturesOutsideBoundingBoxCore(RectangleShape,IEnumerable<String>)
ConvertToInternalProjection(IEnumerable<Feature>)
GetColumnNamesOutsideFeatureSource(IEnumerable<String>)
GetReturningColumnNames(ReturningColumnsType)
RemoveEmptyAndExcludeFeatures(Collection<Feature>)
GetFeaturesByActionWithStyleFilters(IEnumerable<String>,IEnumerable<String>,ZoomLevel,Func<Collection<Feature»,IEnumerable<String>,RectangleShape)
ApplyLinkColumnValues(IEnumerable<String>,Func<IEnumerable<String>,Collection<Feature»,IEnumerable<String>)
ApplyLinkColumnValues(IEnumerable<Feature>,IEnumerable<String>,IEnumerable<String>,IEnumerable<String>)
GetRequiredColumnNamesForLink(IEnumerable<String>)
GetReturningColumnNamesForLink(IEnumerable<String>,IEnumerable<String>)
CheckHasLinkColumns(IEnumerable<String>,IEnumerable<String>)
OnApplyingFilters(ApplyingFiltersFeatureSourceEventArgs)
ConvertToExternalProjectionIfNecessary(Collection<Feature>)
ProcessTransaction(RectangleShape,Collection<Feature>,Boolean)
GetWrappingFeaturesLeft(RectangleShape,Double,Double,IEnumerable<String>,RectangleShape)
GetWrappingFeaturesRight(RectangleShape,Double,Double,IEnumerable<String>,RectangleShape)
GetFeaturesForDrawingCore(RectangleShape,Double,Double,IEnumerable<String>)
SpatialQueryCore(BaseShape,QueryType,IEnumerable<String>)
GetFeaturesNearestToCore(BaseShape,GeographyUnit,Int32,IEnumerable<String>)
GetFeaturesWithinDistanceOfCore(BaseShape,GeographyUnit,DistanceUnit,Double,IEnumerable<String>)
GetBoundingBoxByIdCore(String)
ConvertToExternalProjection(IEnumerable<RectangleShape>)
ConvertToInternalProjection(IEnumerable<RectangleShape>)
OnGettingFeaturesByIds(GettingFeaturesByIdsFeatureSourceEventArgs)
GetFeaturesByColumnValueCore(String,String,IEnumerable<String>)
This property allows you to modify and inspect the InternalFeatures held by this FeatureSource in memory. You can use this as a quick way to add, update or remove InternalFeatures.
This property returns if the FeatureSource allows edits or is read only.
This property is useful to check if a specific FeatureSource accepts editing. If you call the BeginTransaction and this property is false then an exception will be raised. For developers who are creating or extending a FeatureSource it is expected that you override this virtual method if the new FeatureSource you are creating allows edits. By default the decimalDegreesValue if false meaning that if you want to allow edits you must override this method and return true.
You should set the column names for the data that the InternalFeatures will hold. For example, if you have some features that represent road signs, then one column you may want to add is “Sign Type”. Then, for every Feature you add to the layer, you need to add the “Sign Type” and a value to the InternalFeatures' ColumnValues dictionary. If you provide this information, then you can use things like ValueStyles, Labeling, etc. based on the columns you have defined.
Event Arguments:ClosedFeatureSourceEventArgs
