thinkgeo.mapsuite.formsedition.mapview
Table of Contents
ThinkGeo.MapSuite.FormsEdition.MapView
<!– Class –> This class represents the map control.
The map class inherits from the View, so it can be dragged onto the page or be created and added to a contoller via code like the popular control itself. You also need to configure the properties of the map. The most important step is adding overlays, which generate images and stack them over each other to form a map image. The map control has many methods and events through which you can interact with the map.
*System.Object Xamarin.Forms.BindableObject *Xamarin.Forms.Element Xamarin.Forms.VisualElement *Xamarin.Forms.View **ThinkGeo.MapSuite.FormsEdition.MapView
Public MethodMapView Initializes a new instance of the class.
Public MethodBatchBegin VisualElement
Public MethodBatchCommit VisualElement
Public MethodCenterAt PointShape Locates the map center to the specified world point.
Public MethodCenterAt Feature
Public MethodCenterAt Double, Double
Public MethodClearValue BindablePropertyKey BindableObject
Public MethodClearValue BindableProperty BindableObject
Public MethodDispose Performs application-defined tasks associated with freeing, releasing, or resetting unmanaged resources.
Public MethodFindFeatureLayer String Finds the feature layer.
Public MethodFocus VisualElement
Public MethodGetSizeRequest Double, Double VisualElement
Public MethodGetType Object
Public MethodGetValue BindableProperty BindableObject
Public MethodLayout Rectangle VisualElement
Public MethodRefresh This method will simulate the Refresh interaction. Refreshes current map control.
Public MethodRemoveBinding BindableProperty BindableObject
Public MethodRemoveDynamicResource BindableProperty Element
Public MethodSetBinding BindableProperty, BindingBase BindableObject
Public MethodSetDynamicResource BindableProperty, String Element
Public MethodSetValue BindableProperty, Object BindableObject
Public MethodSetValue BindablePropertyKey, Object BindableObject
Public MethodToString Object
Public MethodUnfocus VisualElement
Public MethodZoomTo BaseShape This method zooms current map to the target shape.
Public MethodZoomTo Feature This method zooms current map to the specified feature.
Public MethodZoomTo PointShape, Double This method zooms current map to a specified position and scale.
Public MethodZoomToNextExtent
Public MethodZoomToPreviousExtent
Public MethodZoomToScale Double Zooms the map to a provided scale. This method will simulate the ZoomToScale interaction.
Protected MethodApplyBindings Object BindableObject
Protected MethodDispose Boolean Releases unmanaged and - optionally - managed resources.
Protected MethodFinalize Object(overriden) Finalizes an instance of the class.
Protected MethodInvalidateMeasure VisualElement
Protected MethodOnBindingContextChanged BindableObject(overriden)
Protected MethodOnChildAdded Element Element
Protected MethodOnChildRemoved Element Element
Protected MethodOnChildrenReordered VisualElement
Protected MethodOnCurrentExtentChanged CurrentExtentChangedMapViewEventArgs
Protected MethodOnCurrentExtentChanging CurrentExtentChangingMapViewEventArgs
Protected MethodOnCurrentScaleChanged CurrentScaleChangedMapViewEventArgs
Protected MethodOnCurrentScaleChanging CurrentScaleChangingMapViewEventArgs
Protected MethodOnMapDoubleTap TouchMapViewEventArgs
Protected MethodOnMapLongPress TouchMapViewEventArgs
Protected MethodOnMapSingleTap TouchMapViewEventArgs
Protected MethodOnMapTouchDown TouchMapViewEventArgs
Protected MethodOnMapTouchMove TouchMapViewEventArgs
Protected MethodOnMapTouchUp TouchMapViewEventArgs
Protected MethodOnParentSet Element(overriden)
Protected MethodOnPropertyChanged String BindableObject
Protected MethodOnPropertyChanging String BindableObject
Protected MethodOnSizeAllocated Double, Double VisualElement
Protected MethodOnSizeRequest Double, Double VisualElement
Protected MethodSizeAllocated Double, Double VisualElement
Protected MethodUnapplyBindings BindableObject
Public PropertyAdapter MapElementAdapter Gets the adapter density.
Public PropertyAdornmentOverlay AdornmentOverlay Gets or sets the adornment overlay.
Public PropertyAnchorX Double VisualElement
Public PropertyAnchorY Double VisualElement
Public PropertyBackgroundColor Color VisualElement
Public PropertyBehaviors IList<Behavior> VisualElement
Public PropertyBindingContext Object BindableObject
Public PropertyBounds Rectangle VisualElement
Public PropertyClassId String Element
Public PropertyCurrentExtent RectangleShape Gets or sets the current extent of the MapControl.
Public PropertyDisplayDensity Single Gets the display density.
Public PropertyEditOverlay EditInteractiveOverlay Gets or sets the edit overlay in the MapControl.
Public PropertyGestureRecognizers IList<IGestureRecognizer> View
Public PropertyHeight Double VisualElement
Public PropertyHeightRequest Double VisualElement
Public PropertyHorizontalOptions LayoutOptions View
Public PropertyId Guid Element
Public PropertyInputTransparent Boolean VisualElement
Public PropertyIsEnabled Boolean VisualElement
Public PropertyIsFocused Boolean VisualElement
Public PropertyIsVisible Boolean VisualElement
Public PropertyMapTools MapTools Gets a object for simply using MapTools.
Public PropertyMapUnit GeographyUnit Gets or sets the map unit used by the MapControl.
Public PropertyMinimumHeightRequest Double VisualElement
Public PropertyMinimumWidthRequest Double VisualElement
Public PropertyNavigation INavigation VisualElement
Public PropertyOpacity Double VisualElement
Public PropertyOverlays GeoCollection<Overlay> This property gets the collection of Overlays in the MapControl.
Public PropertyParent Element Element
Public PropertyParentView VisualElement Element
Public PropertyResources ResourceDictionary VisualElement
Public PropertyRotation Double VisualElement
Public PropertyRotationX Double VisualElement
Public PropertyRotationY Double VisualElement
Public PropertyScale Double VisualElement
Public PropertyStyle Style VisualElement
Public PropertyStyleId String Element
Public PropertyTrackOverlay TrackInteractiveOverlay Gets or sets the track overlay in the MapControl.
Public PropertyTranslationX Double VisualElement
Public PropertyTranslationY Double VisualElement
Public PropertyTriggers IList<TriggerBase> VisualElement
Public PropertyVerticalOptions LayoutOptions View
Public PropertyWidth Double VisualElement
Public PropertyWidthRequest Double VisualElement
Public PropertyX Double VisualElement
Public PropertyY Double VisualElement
Public PropertyZoomLevelSet ZoomLevelSet This property gets or sets the ZoomLevelSet used for the MapView control.
Public EventBindingContextChanged EventArgs BindableObject
Public EventChildAdded ElementEventArgs Element
Public EventChildRemoved ElementEventArgs Element
Public EventChildrenReordered EventArgs VisualElement
Public EventCurrentExtentChanged CurrentExtentChangedMapViewEventArgs Occurs after map's extent is changed.
Public EventCurrentExtentChanging CurrentExtentChangingMapViewEventArgs Occurs before map's extent is changing.
Public EventCurrentScaleChanged CurrentScaleChangedMapViewEventArgs Occurs after map's current scale is changed.
Public EventCurrentScaleChanging CurrentScaleChangingMapViewEventArgs Occurs before map's current scale is changing.
Public EventDescendantAdded ElementEventArgs Element
Public EventDescendantRemoved ElementEventArgs Element
Public EventFocused FocusEventArgs VisualElement
Public EventMapDoubleTap TouchMapViewEventArgs Occurs when double tap.
Public EventMapLongPress TouchMapViewEventArgs Occurs when long press.
Public EventMapSingleTap TouchMapViewEventArgs Occurs when single tap.
Public EventMapTouchDown TouchMapViewEventArgs Occurs when touch down.
Public EventMapTouchMove TouchMapViewEventArgs Occurs when touch move.
Public EventMapTouchUp TouchMapViewEventArgs Occurs when touch up.
Public EventMeasureInvalidated EventArgs VisualElement
Public EventPropertyChanged PropertyChangedEventArgs BindableObject
Public EventPropertyChanging PropertyChangingEventArgs BindableObject
Public EventSizeChanged EventArgs VisualElement
Public EventUnfocused FocusEventArgs VisualElement
MapView()
Name Type Description
Go Back
BatchBegin()
Return Type Description
Void<!– System.Void –>
<!– Xamarin.Forms.VisualElement –> Go Back
BatchCommit()
CenterAt(PointShape)
worldCenter PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> A world point to locate the map.
<!– ThinkGeo.MapSuite.FormsEdition.MapView –> Go Back
CenterAt(Feature)
feature Feature<!– ThinkGeo.MapSuite.Core.Feature –>
CenterAt(Double, Double)
worldX Double<!– System.Double –>
worldY Double<!– System.Double –>
ClearValue(BindablePropertyKey)
propertyKey BindablePropertyKey<!– Xamarin.Forms.BindablePropertyKey –>
<!– Xamarin.Forms.BindableObject –> Go Back
ClearValue(BindableProperty)
property BindableProperty<!– Xamarin.Forms.BindableProperty –>
Dispose()
Boolean<!– System.Boolean –>
FindFeatureLayer(String)
FeatureLayer<!– ThinkGeo.MapSuite.Core.FeatureLayer –> FeatureLayer.
layerKey String<!– System.String –> The layer key.
Focus()
Int32<!– System.Int32 –>
GetSizeRequest(Double, Double)
SizeRequest<!– Xamarin.Forms.SizeRequest –>
widthConstraint Double<!– System.Double –>
heightConstraint Double<!– System.Double –>
Type<!– System.Type –>
GetValue(BindableProperty)
Layout(Rectangle)
bounds Rectangle<!– Xamarin.Forms.Rectangle –>
Refresh()
Refreshes all the existing overlays and map tools.
RemoveBinding(BindableProperty)
RemoveDynamicResource(BindableProperty)
<!– Xamarin.Forms.Element –> Go Back
SetBinding(BindableProperty, BindingBase)
targetProperty BindableProperty<!– Xamarin.Forms.BindableProperty –>
binding BindingBase<!– Xamarin.Forms.BindingBase –>
SetDynamicResource(BindableProperty, String)
key String<!– System.String –>
SetValue(BindableProperty, Object)
value Object<!– System.Object –>
SetValue(BindablePropertyKey, Object)
Unfocus()
ZoomTo(BaseShape)
When calling this method, it doesn't refresh existing Tiles on the current map. For example, if using a TileOverlay such as LayerOverlay; a layer style is changed, Refresh method is proper to call.
targetShape BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –>
ZoomTo(Feature)
feature Feature<!– ThinkGeo.MapSuite.Core.Feature –> A feature to locates the map.
ZoomTo(PointShape, Double)
targetScale Double<!– System.Double –> A double value indicates the scale to zoom the map to.
ZoomToNextExtent()
ZoomToPreviousExtent()
ZoomToScale(Double)
targetScale Double<!– System.Double –> A target scale to zoom the map.
ApplyBindings(Object)
oldContext Object<!– System.Object –>
Dispose(Boolean)
disposing Boolean<!– System.Boolean –> true to release both managed and unmanaged resources; false to release only unmanaged resources.
InvalidateMeasure()
OnBindingContextChanged()
<!– Xamarin.Forms.BindableObject(overriden) –> Go Back
OnChildAdded(Element)
child Element<!– Xamarin.Forms.Element –>
OnChildRemoved(Element)
OnChildrenReordered()
OnCurrentExtentChanged(CurrentExtentChangedMapViewEventArgs)
e CurrentExtentChangedMapViewEventArgs<!– ThinkGeo.MapSuite.FormsEdition.CurrentExtentChangedMapViewEventArgs –>
OnCurrentExtentChanging(CurrentExtentChangingMapViewEventArgs)
e CurrentExtentChangingMapViewEventArgs<!– ThinkGeo.MapSuite.FormsEdition.CurrentExtentChangingMapViewEventArgs –>
OnCurrentScaleChanged(CurrentScaleChangedMapViewEventArgs)
e CurrentScaleChangedMapViewEventArgs<!– ThinkGeo.MapSuite.FormsEdition.CurrentScaleChangedMapViewEventArgs –>
OnCurrentScaleChanging(CurrentScaleChangingMapViewEventArgs)
e CurrentScaleChangingMapViewEventArgs<!– ThinkGeo.MapSuite.FormsEdition.CurrentScaleChangingMapViewEventArgs –>
OnMapDoubleTap(TouchMapViewEventArgs)
e TouchMapViewEventArgs<!– ThinkGeo.MapSuite.FormsEdition.TouchMapViewEventArgs –>
OnMapLongPress(TouchMapViewEventArgs)
OnMapSingleTap(TouchMapViewEventArgs)
OnMapTouchDown(TouchMapViewEventArgs)
OnMapTouchMove(TouchMapViewEventArgs)
OnMapTouchUp(TouchMapViewEventArgs)
OnParentSet()
<!– Xamarin.Forms.Element(overriden) –> Go Back
OnPropertyChanged(String)
propertyName String<!– System.String –>
OnPropertyChanging(String)
OnSizeAllocated(Double, Double)
width Double<!– System.Double –>
height Double<!– System.Double –>
OnSizeRequest(Double, Double)
UnapplyBindings()
Adapter
Return Type
MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –>
AdornmentOverlay
Return Type
AdornmentOverlay<!– ThinkGeo.MapSuite.FormsEdition.AdornmentOverlay –>
AnchorX
Return Type
AnchorY
Return Type
BackgroundColor
Return Type
Color<!– Xamarin.Forms.Color –>
Behaviors
Return Type
IList<Behavior><!– System.Collections.Generic.IList{Xamarin.Forms.Behavior} –>
BindingContext
Return Type
Bounds
Return Type
ClassId
Return Type
CurrentExtent
The current extent stands for the extent of current position, this is very important metrics to caculate the scale.
Return Type
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
DisplayDensity
Return Type
Single<!– System.Single –>
EditOverlay
Return Type
EditInteractiveOverlay<!– ThinkGeo.MapSuite.FormsEdition.EditInteractiveOverlay –>
GestureRecognizers
Return Type
IList<IGestureRecognizer><!– System.Collections.Generic.IList{Xamarin.Forms.IGestureRecognizer} –>
<!– Xamarin.Forms.View –> Go Back
Height
Return Type
HeightRequest
Return Type
HorizontalOptions
Return Type
LayoutOptions<!– Xamarin.Forms.LayoutOptions –>
Id
Return Type
Guid<!– System.Guid –>
InputTransparent
Return Type
IsEnabled
Return Type
IsFocused
Return Type
IsVisible
Return Type
MapTools
Return Type
MapTools<!– ThinkGeo.MapSuite.FormsEdition.MapTools –>
MapUnit
The MapUnit reflects the data unit.
Return Type
GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –>
Return Type
MinimumWidthRequest
Return Type
Return Type
INavigation<!– Xamarin.Forms.INavigation –>
Opacity
Return Type
Overlays
Return Type
GeoCollection<Overlay><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.FormsEdition.Overlay} –>
Parent
Return Type
ParentView
Return Type
VisualElement<!– Xamarin.Forms.VisualElement –>
Resources
Return Type
ResourceDictionary<!– Xamarin.Forms.ResourceDictionary –>
Rotation
Return Type
RotationX
Return Type
RotationY
Return Type
Scale
Return Type
Style
Return Type
Style<!– Xamarin.Forms.Style –>
StyleId
Return Type
TrackOverlay
Return Type
TrackInteractiveOverlay<!– ThinkGeo.MapSuite.FormsEdition.TrackInteractiveOverlay –>
TranslationX
Return Type
TranslationY
Return Type
Triggers
Return Type
IList<TriggerBase><!– System.Collections.Generic.IList{Xamarin.Forms.TriggerBase} –>
VerticalOptions
Return Type
Width
Return Type
WidthRequest
Return Type
X
Return Type
Y
Return Type
ZoomLevelSet
Return Type
ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –>
Event Arguments
Event Arguments
EventArgs<!– System.EventArgs –>
ChildAdded
Event Arguments
Event Arguments
ElementEventArgs<!– Xamarin.Forms.ElementEventArgs –>
ChildRemoved
Event Arguments
Event Arguments
ChildrenReordered
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
Event Arguments
CurrentScaleChanged
Event Arguments
Event Arguments
Event Arguments
Event Arguments
DescendantAdded
Event Arguments
Event Arguments
DescendantRemoved
Event Arguments
Event Arguments
Focused
Event Arguments
Event Arguments
FocusEventArgs<!– Xamarin.Forms.FocusEventArgs –>
MapDoubleTap
Event Arguments
Event Arguments
MapLongPress
Event Arguments
Event Arguments
MapSingleTap
Event Arguments
Event Arguments
MapTouchDown
Event Arguments
Event Arguments
MapTouchMove
Event Arguments
Event Arguments
MapTouchUp
Event Arguments
Event Arguments
MeasureInvalidated
Event Arguments
Event Arguments
PropertyChanged
Event Arguments
Event Arguments
PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –>
PropertyChanging
Event Arguments
Event Arguments
PropertyChangingEventArgs<!– Xamarin.Forms.PropertyChangingEventArgs –>
SizeChanged
Event Arguments
Event Arguments
Unfocused
Event Arguments
Event Arguments
NOTOC MapSuiteFormsEdition ThinkGeo.MapSuite.FormsEdition UpdateDocumentation
thinkgeo.mapsuite.formsedition.mapview.txt · Last modified: 2017/03/16 21:59 (external edit)
