thinkgeo.mapsuite.core.transactionresult
ThinkGeo.MapSuite.Core.TransactionResult
    • ThinkGeo.MapSuite.Core.TransactionResult
TransactionResult()
  • This is the class constructor.
  • This is the default constructor and is typically not used.
TransactionResult(Int32,Int32,Dictionary<String,String>,TransactionResultStatus)
  • totalSuccessCount
  • totalFailureCount
  • failureReasons
TotalSuccessCount
This property gets and sets the total number of records that we committed successfully.
TotalFailureCount
This property gets and sets the total number of records that we committed unsuccessfully.
This property gets and sets the result status of the transaction.
This property returns the results of the transaction. If all of the records committed fine then you get a success status. If any of the records fail then you get a failure status though some of the records may have committed.
FailureReasons
This property gets and sets the dictionary that contains the reasons for failure.
If there are failing records we suggest you add the failure reasons to this dictionary. It is also suggested that you use the FeatureId as the key of the Dictionary.
thinkgeo.mapsuite.core.transactionresult.txt · Last modified: 2017/03/16 21:59 (external edit)
