AddFeature(BaseShape,Dictionary<String,String>)
EditFeature(BaseShape,Dictionary<String,String>)
AddColumn(FeatureSourceColumn)
It is recommended that you use this dictionary for reviewing and not for adding new items. The reason is that the Add, Delete and Edit methods to various validation checks. For example if you call the DeleteFeature twice it will handle the case that you really only want to delete the record once. Another example is if you edit a record twice it will replace the existing edit with the new one.
This property gets the dictionary buffer that holds InternalFeatures to be deleted.
This property gets the dictionary buffer that holds InternalFeatures to be updated.
