This class is a single item in an IconValueStyle.
IconValueItem(String,GeoImage,TextStyle)
This property gets and sets the field value that has to match in the IconValueStyle.
For an explanation on how the IconValueStyle works, see the IconValueStyle Class remarks.
This property gets and sets the path and filename of the icon that will be drawn.
If you need to use a GeoImage, you can set the GeoImage in the constructor or use the property.
This property gets and sets the minimum string length for this item to match.
This is an important property because it is used to ensure that that a properly sized icon is used to draw things like road signs. For example, you can set the minimum and maximum values so that the sign icon for a single-digit road number uses one icon, while a two-digit road uses another, wider sign icon in a separate IconValueItem.
This property gets and sets the maximum string length for this item to match.
