thinkgeo.mapsuite.silverlightedition.markerzoomlevelset
ThinkGeo.MapSuite.SilverlightEdition.MarkerZoomLevelSet
This class represents a collection of MarkerZoomLevel that determines the appearance of markers at different zoomlevels.
    • ThinkGeo.MapSuite.SilverlightEdition.MarkerZoomLevelSet
MarkerZoomLevelSet()
  • Initialize a new instance of the MarkerZoomLevelSet class.
GetZoomLevelForDrawing(Int32)
  • Returns the MarkerZoomLevel object whose styles will be applies to the markers base on the current zoomlevel that passed in.
  • currentZoomLevelId
    • Description:An int value that indicates which zoomlevel is the current zoomlevel. The int value can only be in 1-20.
rhQ=(Int32)
  • id
ZoomLevel01
Gets the MarkerZoomLevel for Level01.
ZoomLevel02
Gets the MarkerZoomLevel for Level02.
ZoomLevel03
Gets the MarkerZoomLevel for Level03.
ZoomLevel04
Gets the MarkerZoomLevel for Level04.
ZoomLevel05
Gets the MarkerZoomLevel for Level05.
ZoomLevel06
Gets the MarkerZoomLevel for Level06.
ZoomLevel07
Gets the MarkerZoomLevel for Level07.
ZoomLevel08
Gets the MarkerZoomLevel for Level08.
ZoomLevel09
Gets the MarkerZoomLevel for Level09.
ZoomLevel10
Gets the MarkerZoomLevel for Level10.
ZoomLevel11
Gets the MarkerZoomLevel for Level11.
ZoomLevel12
Gets the MarkerZoomLevel for Level12.
ZoomLevel13
Gets the MarkerZoomLevel for Level13.
ZoomLevel14
Gets the MarkerZoomLevel for Level14.
ZoomLevel15
Gets the MarkerZoomLevel for Level15.
ZoomLevel16
Gets the MarkerZoomLevel for Level16.
ZoomLevel17
Gets the MarkerZoomLevel for Level17.
ZoomLevel18
Gets the MarkerZoomLevel for Level18.
ZoomLevel19
Gets the MarkerZoomLevel for Level19.
ZoomLevel20
Gets the MarkerZoomLevel for Level20.
CustomZoomLevels
Gets a MarkerZoomLevel collection that is used for you to define your own custom zoomlevels.
When you add custom zoomlevels to the CustomZoomLevels collection, the default ZoomLevel01-20 will be disabled. The zoomLevels in the CustomZoomLevels are matched with the scales defined in the Map.ClientZoomLevelScales. For example,CustomZoomLevels[0] has the scale that equals to Map.ClientZoomLevelScales[0].
thinkgeo.mapsuite.silverlightedition.markerzoomlevelset.txt · Last modified: 2017/03/16 21:59 (external edit)
