thinkgeo.mapsuite.silverlightedition.markerzoomlevel
ThinkGeo.MapSuite.SilverlightEdition.MarkerZoomLevel
This class defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
    • ThinkGeo.MapSuite.SilverlightEdition.MarkerZoomLevel
MarkerZoomLevel()
This is the constructor of MarkerZoomLevel class.
GetMarkers(IEnumerable<Feature>)
This method returns a collection of markers that is applied with the styles when the current zoomlevel falls into the ranges that defined.
  • Type:Collection<Marker>
  • Description:A Collection of markers that created from the feature collection.
  • features
    • Type:IEnumerable<Feature>
    • Description:A collection of features that is applied with the styles when the current zoomlevel falls into the ranges that defined.
ApplyUntilZoomLevel
Gets or sets the zoomlevel to which the styles will be applied.
DefaultMarkerStyle
Gets or sets default style that is applied to the markers if the CustomMarkerStyle is not defined.
Gets or sets the style that is applied to the markers if the CustomMarkerStyle is not defined.
CustomMarkerStyle
Gets or sets a custom style that can be any type of MarkerStyle.
The CustomMarkerStyle has a higher priority than the DefaultMarkerStyle. When you define both styles, the CustomMarkerStyle will be applied. The CustomMarkerStyle can be any kind of MarkStyle while DefaultMarkerStyle can not.
qxQ=
thinkgeo.mapsuite.silverlightedition.markerzoomlevel.txt · Last modified: 2017/03/16 21:59 (external edit)
