thinkgeo.mapsuite.silverlightedition.marker
ThinkGeo.MapSuite.SilverlightEdition.Marker
This class represents a small icon on the map that is used for marking a point.
    • System.Windows.DependencyObject
      • System.Windows.UIElement
        • System.Windows.FrameworkElement
          • System.Windows.Controls.Control
            • ThinkGeo.MapSuite.SilverlightEdition.Marker
Marker()
  • This is the constructor of the Marker class.
Marker(Double,Double)
  • worldX
    • Description:A double value indicating the world x coordinate of the Marker
  • worldY
    • Description:A double value indicating the world y coordinate of the Marker
Marker(PointShape)
  • position
    • Description:A PointShape that specifies the position of the Marker
Marker(Point)
  • position
    • Type:Point
    • Description:A Point that specifies the position of the Marker
OnApplyTemplate()
  • Builds the visual tree for the GeoPopup control when a new template is applied.
Focus()
ApplyTemplate()
FindName(String)
  • name
SetBinding(DependencyProperty,Binding)
  • Type:BindingExpressionBase
  • dp
    • Type:DependencyProperty
  • binding
    • Type:Binding
GetBindingExpression(DependencyProperty)
  • dp
AddHandler(RoutedEvent,Delegate,Boolean)
  • routedEvent
    • Type:RoutedEvent
  • handler
    • Type:Delegate
  • handledEventsToo
RemoveHandler(RoutedEvent,Delegate)
  • routedEvent
    • Type:RoutedEvent
  • handler
    • Type:Delegate
TransformToVisual(UIElement)
  • Type:GeneralTransform
  • visual
    • Type:UIElement
Measure(Size)
  • availableSize
    • Type:Size
Arrange(Rect)
  • finalRect
    • Type:Rect
CaptureMouse()
ReleaseMouseCapture()
InvalidateMeasure()
InvalidateArrange()
UpdateLayout()
CheckAccess()
SetValue(DependencyProperty,Object)
  • dp
  • value
ClearValue(DependencyProperty)
  • dp
ReadLocalValue(DependencyProperty)
  • dp
GetAnimationBaseValue(DependencyProperty)
  • dp
GetValue(DependencyProperty)
  • dp
OnDrop(DragEventArgs)
  • e
    • Type:DragEventArgs
NativeMouseMove(MouseEventArgs)
  • e
    • Type:MouseEventArgs
NativeMouseEnter(MouseEventArgs)
  • e
NativeMouseLeave(MouseEventArgs)
  • e
NativeMouseLeftButtonDown(MouseButtonEventArgs)
  • e
    • Type:MouseButtonEventArgs
NativeMouseLeftButtonUp(MouseButtonEventArgs)
  • e
NativeMouseRightButtonDown(MouseButtonEventArgs)
  • e
NativeMouseRightButtonUp(MouseButtonEventArgs)
  • e
NativeMouseWheel(MouseWheelEventArgs)
  • e
    • Type:MouseWheelEventArgs
NativeKeyUp(KeyEventArgs)
  • e
    • Type:KeyEventArgs
NativeKeyDown(KeyEventArgs)
  • e
    • Type:KeyEventArgs
NativeGotFocus(RoutedEventArgs)
  • e
    • Type:RoutedEventArgs
NativeLostFocus(RoutedEventArgs)
  • e
NativeIsEnabledChanged(IsEnabledChangedEventArgs)
  • e
    • Type:IsEnabledChangedEventArgs
GetValueFromBuiltInStyle(DependencyProperty,Object&)
  • property
  • value
    • Type:Object&
NativeOnLostMouseCapture(MouseEventArgs)
  • e
NativeTextInput(TextCompositionEventArgs)
  • e
    • Type:TextCompositionEventArgs
NativeTextInputStart(TextCompositionEventArgs)
  • e
NativeTextInputUpdate(TextCompositionEventArgs)
  • e
NativeDragEnter(DragEventArgs)
  • e
NativeDragLeave(DragEventArgs)
  • e
NativeDragOver(DragEventArgs)
  • e
NativeDrop(DragEventArgs)
  • e
ShowValidationError()
HideValidationError()
UpdateValidationState()
OnManipulationStarted(ManipulationStartedEventArgs)
  • e
    • Type:ManipulationStartedEventArgs
OnManipulationDelta(ManipulationDeltaEventArgs)
  • e
    • Type:ManipulationDeltaEventArgs
OnManipulationCompleted(ManipulationCompletedEventArgs)
  • e
    • Type:ManipulationCompletedEventArgs
OnTap(GestureEventArgs)
  • e
    • Type:GestureEventArgs
OnDoubleTap(GestureEventArgs)
  • e
OnHold(GestureEventArgs)
  • e
GetTemplateChild(String)
  • Type:DependencyObject
  • childName
RemoveTemplateBinding(FrameworkElement,DependencyProperty)
  • target
    • Type:FrameworkElement
  • targetProperty
GoToState(Boolean,String)
  • useTransitions
  • stateName
OnMouseMove(MouseEventArgs)
  • e
OnMouseEnter(MouseEventArgs)
  • e
OnMouseLeave(MouseEventArgs)
  • e
OnMouseLeftButtonDown(MouseButtonEventArgs)
  • e
OnMouseLeftButtonUp(MouseButtonEventArgs)
  • e
OnMouseRightButtonDown(MouseButtonEventArgs)
  • e
OnMouseRightButtonUp(MouseButtonEventArgs)
  • e
OnMouseWheel(MouseWheelEventArgs)
  • e
OnKeyUp(KeyEventArgs)
  • e
    • Type:KeyEventArgs
OnKeyDown(KeyEventArgs)
  • e
    • Type:KeyEventArgs
OnGotFocus(RoutedEventArgs)
  • e
OnLostFocus(RoutedEventArgs)
  • e
OnIsEnabledChanged(IsEnabledChangedEventArgs)
  • e
  • e
OnTextInput(TextCompositionEventArgs)
  • e
OnTextInputStart(TextCompositionEventArgs)
  • e
OnTextInputUpdate(TextCompositionEventArgs)
  • e
OnDragEnter(DragEventArgs)
  • e
OnDragLeave(DragEventArgs)
  • e
OnDragOver(DragEventArgs)
  • e
ApplyTemplateInternal()
GetValueInternal(DependencyProperty)
  • dp
MeasureOverride(Size)
  • Type:Size
  • availableSize
    • Type:Size
ArrangeOverride(Size)
  • Type:Size
  • finalSize
    • Type:Size
OnTreeParentUpdated(DependencyObject,Boolean)
  • newParent
  • bIsNewParentAlive
NotifyDataContextChanged(DataContextChangedEventArgs)
  • e
    • Type:DataContextChangedEventArgs
OnBindingValidationError(ValidationErrorEventArgs)
  • args
    • Type:ValidationErrorEventArgs
CalculateBubblePath()
  • Type:List<FrameworkElement>
RaiseBindingValidationError(ValidationErrorEventArgs)
  • args
OnSizeChanged(Object,SizeChangedEventArgs)
  • sender
  • e
    • Type:SizeChangedEventArgs
OnAncestorDataContextChanged(DataContextChangedEventArgs)
  • e
IsDataContextChangeRelevant(DataContextChangedEventArgs)
  • e
OnDataContextChanged(DataContextChangedEventArgs)
  • e
OnPropertyChanged(DependencyProperty)
  • dp
GetValueFromStyle(DependencyProperty,Object&)
  • property
  • value
    • Type:Object&
HasFocus()
FindNameInPage(String,Boolean)
  • name
  • calledFromUserControl
GetPlainText()
HitTest(Point)
  • Type:IEnumerable<UIElement>
  • point
    • Type:Point
HitTest(Rect)
  • rect
    • Type:Rect
IsAncestorOf(UIElement)
  • element
    • Type:UIElement
OnCreateAutomationPeer()
  • Type:AutomationPeer
GetOrCreateAutomationPeer()
GetAutomationPeer()
InvalidateAutomationPeer()
GetChildrenCount()
GetChild(Int32)
  • Type:UIElement
  • childIndex
BringIntoView()
BringIntoView(Rect)
  • targetRectangle
    • Type:Rect
GetIsUnloadingNode()
PegManagedPeerNoRef()
UnpegManagedPeerNoRef()
GetManagedReference(UInt32)
  • nPropertyID
    • Type:UInt32
RefreshExpression(DependencyProperty)
  • dp
EnsureValueTable()
SetValueInternal(DependencyProperty,Object)
  • dp
  • value
SetValueInternal(DependencyProperty,Object,Boolean)
  • dp
  • value
  • allowReadOnlySet
SetValueInternal(DependencyProperty,Object,Boolean,Boolean)
  • dp
  • value
  • allowReadOnlySet
  • isBindingInStyleSetter
ClearValueInternal(DependencyProperty)
  • dp
ReadLocalValueInternal(DependencyProperty)
  • dp
IsPropertyDefault(DependencyProperty)
  • dp
GetMentor()
PrepareCorePropertyExpression(DependencyProperty,Object)
  • property
  • value
InvalidateStyleBinding(DependencyProperty,Boolean&)
  • dp
  • hasLocalOrAnimatedValue
    • Type:Boolean&
SetValue(DependencyProperty,Matrix)
  • property
  • m
    • Type:Matrix
SetValue(DependencyProperty,Matrix3D)
  • property
  • m
    • Type:Matrix3D
SetValue(DependencyProperty,Point)
  • property
  • p
    • Type:Point
SetValue(DependencyProperty,DependencyObject)
  • property
  • doh
SetValue(DependencyProperty,Int32)
  • property
  • i
SetValue(DependencyProperty,Boolean)
  • property
  • b
SetValue(DependencyProperty,Enum)
  • property
  • e
    • Type:Enum
SetValue(DependencyProperty,Color)
  • property
  • c
    • Type:Color
SetValue(DependencyProperty,Double)
  • property
  • d
SetValue(DependencyProperty,GridLength)
  • property
  • g
    • Type:GridLength
InvalidateProperty(DependencyProperty)
  • property
GetOldValue(DependencyProperty,EffectiveValueEntry&)
  • property
  • oldEntry
    • Type:EffectiveValueEntry&
GetNewValue(DependencyProperty,EffectiveValueEntry&)
  • property
  • newEntry
SetEffectiveValue(DependencyProperty,EffectiveValueEntry&,Object)
  • property
  • newEntry
  • newValue
UpdateParentInheritanceContextPropagation()
SetAnimatedValue(DependencyProperty,Object)
  • property
  • animatedValue
ClearAnimatedValue(DependencyProperty,Boolean,Object)
  • property
  • hasHoldEndValue
  • holdEndValue
OnInheritanceContextChanged(Object,EventArgs)
  • sender
  • e
    • Type:EventArgs
AddEventListener(DependencyProperty,Delegate)
  • property
  • handler
    • Type:Delegate
AddEventListener(DependencyProperty,Delegate,Boolean)
  • property
  • handler
    • Type:Delegate
  • handledEventsToo
RemoveEventListener(DependencyProperty,Delegate)
  • property
  • handler
    • Type:Delegate
UpdateTreeParent(IManagedPeer,IManagedPeer,Boolean,Boolean)
  • oldParent
    • Type:IManagedPeer
  • newParent
    • Type:IManagedPeer
  • bIsNewParentAlive
  • keepReferenceToParent
UpdateTreeParentHelper(IManagedPeer,IManagedPeer,Boolean)
  • oldParent
    • Type:IManagedPeer
  • newParent
    • Type:IManagedPeer
IsPropertyLocal(CoreDependencyProperty)
  • dp
    • Type:CoreDependencyProperty
OnParentEnter(IntPtr,UInt32,UInt32,UInt32,UInt32)
  • nativeNamescopeOwner
    • Type:IntPtr
  • bLive
    • Type:UInt32
  • bSkipNameRegistration
    • Type:UInt32
  • bCoercedIsEnabled
    • Type:UInt32
  • bUseLayoutRounding
    • Type:UInt32
Popup
Gets or sets the shortcut menu associated with the marker.
PopupDelay
Gets or sets a value indicating the interval that should elapse between when the mouse moves over the marker and when its popup window displays.
  • Type:TimeSpan
Position
Gets or sets a Point object that represents the current location of the marker.
  • Type:Point
ImageWidth
Gets or sets the width of the web image.
ImageHeight
Gets or sets the height of the marker image.
ImageOffsetX
Gets or sets the image's X offset in screen coordinates.
ImageOffsetY
Gets or sets the image's Y offset in screen coordinates.
ImageSource
Gets or sets an ImageSource for the marker icon.
  • Type:ImageSource
ImageRotationAngle
Gets or sets the rotation angle of the marker image by degree.
TextRotationAngle
Gets or sets the rotation angle of the marker text by degree.
Text
Gets or sets the text displayed on the image.
TextWrapping
Gets or sets whether text is wrapping or not when it reaches the edge of its container.
  • Type:TextWrapping
TextWidth
Gets or sets the width of text on the marker.
TextOffsetX
Gets or sets the x offset of text on the marker.
TextOffsetY
Gets or sets the y offset of text on the marker.
FontSize
FontFamily
  • Type:FontFamily
FontWeight
  • Type:FontWeight
FontStyle
  • Type:FontStyle
FontStretch
  • Type:FontStretch
CharacterSpacing
Foreground
  • Type:Brush
IsTabStop
IsEnabled
TabIndex
TabNavigation
  • Type:KeyboardNavigationMode
Template
  • Type:ControlTemplate
Padding
  • Type:Thickness
HorizontalContentAlignment
  • Type:HorizontalAlignment
VerticalContentAlignment
  • Type:VerticalAlignment
Background
  • Type:Brush
BorderThickness
  • Type:Thickness
BorderBrush
  • Type:Brush
Triggers
  • Type:TriggerCollection
Resources
  • Type:ResourceDictionary
ActualWidth
ActualHeight
Width
Height
MinWidth
MaxWidth
MinHeight
MaxHeight
HorizontalAlignment
VerticalAlignment
Margin
  • Type:Thickness
Style
  • Type:Style
Parent
FlowDirection
  • Type:FlowDirection
Tag
Cursor
  • Type:Cursor
Language
  • Type:XmlLanguage
DataContext
AllowDrop
Opacity
Clip
  • Type:Geometry
Effect
  • Type:Effect
Projection
  • Type:Projection
OpacityMask
  • Type:Brush
RenderTransformOrigin
  • Type:Point
IsHitTestVisible
Visibility
  • Type:Visibility
RenderSize
  • Type:Size
UseLayoutRounding
CacheMode
  • Type:CacheMode
DesiredSize
  • Type:Size
RenderTransform
  • Type:Transform
Dispatcher
  • Type:Dispatcher
hRQ=
ImplementationRoot
DefaultStyleKey
TagInternal
TemplatedParent
IsDataContextBound
IsDataContextChangingInternal
ChildrenInternal
  • Type:UIElementCollection
NativeObject
  • Type:IntPtr
NativeObjectSafeHandle
  • Type:NativeObjectSafeHandle
NeedsInheritanceContextChanges
IsInLiveTree
IsEnabledChanged N/A
Event Arguments:
Loaded N/A
Event Arguments:
Unloaded N/A
Event Arguments:
SizeChanged N/A
Event Arguments:
LayoutUpdated N/A
Event Arguments:
BindingValidationError N/A
Event Arguments:ValidationErrorEventArgs
DataContextChanged N/A
Event Arguments:
MouseMove N/A
Event Arguments:
MouseEnter N/A
Event Arguments:
MouseLeave N/A
Event Arguments:
MouseLeftButtonDown N/A
Event Arguments:
MouseLeftButtonUp N/A
Event Arguments:
MouseRightButtonDown N/A
Event Arguments:
MouseRightButtonUp N/A
Event Arguments:
MouseWheel N/A
Event Arguments:
KeyUp N/A
Event Arguments:
KeyDown N/A
Event Arguments:
MediaCommand N/A
Event Arguments:
GotFocus N/A
Event Arguments:
LostFocus N/A
Event Arguments:
LostMouseCapture N/A
Event Arguments:
TextInput N/A
Event Arguments:
TextInputStart N/A
Event Arguments:
TextInputUpdate N/A
Event Arguments:
DragEnter N/A
Event Arguments:
DragLeave N/A
Event Arguments:
DragOver N/A
Event Arguments:
Drop N/A
Event Arguments:
ManipulationStarted N/A
Event Arguments:ManipulationStartedEventArgs
ManipulationDelta N/A
Event Arguments:ManipulationDeltaEventArgs
ManipulationCompleted N/A
Event Arguments:ManipulationCompletedEventArgs
Tap N/A
Event Arguments:GestureEventArgs
DoubleTap N/A
Hold N/A
thinkgeo.mapsuite.silverlightedition.marker.txt · Last modified: 2017/03/16 21:59 (external edit)
