thinkgeo.mapsuite.silverlightedition.pointmarkerstyle
ThinkGeo.MapSuite.SilverlightEdition.PointMarkerStyle
This class represents the ordinary point marker style.
    • ThinkGeo.MapSuite.SilverlightEdition.MarkerStyle
      • ThinkGeo.MapSuite.SilverlightEdition.PointMarkerStyle
PointMarkerStyle()
This is constructor of the PointMarkerStyle class.
PointMarkerStyle(ImageSource)
  • imageSource
    • Type:ImageSource
    • Description:An ImageSource value indicating the icon source for the marker.
PointMarkerStyle(ImageSource,GeoPopup)
  • imageSource
    • Type:ImageSource
  • popup
    • Type:GeoPopup
    • Description:A GeoPopup value indicating the popup display when mouse hover on the marker.
GetMarkers(IEnumerable<Feature>)
This method returns a collection of markers that created with specific styles from the features passed in.
  • Type:Collection<Marker>
  • Description:A collection of markers that create from the features.
  • features
    • Type:IEnumerable<Feature>
    • Description:A collection of features that the markers are created from.
Popup
Gets or sets the popup object that displays when the mouse pointer is over a marker.
PopupDelay
Gets or sets a TimeSpan value that indicates the time that between the mouse is over a marker and the popup shows.
The PopupDelay value is count in TimeSpan which delays the popup displaying after the value as the mouse hovering on the marker.
  • Type:TimeSpan
ImageSource
Gets or sets the small image that the marker displays.
  • Type:ImageSource
Opacity
Gets or sets a double value between 0 and 1 that indicates the transparency level of the marker.
The Opacity property enables you to specify a level of transparency for the marker. When this property is set to a value less than 100 percent(1.00), the entire overlay is made more transparent. Setting this property to a value of 0 percent (0.00) makes the marker completely invisible.
ImageWidth
Gets or sets the width in pixel of the web image.
ImageHeight
Gets or sets the height in pixel of the web image.
ImageOffsetX
Gets or sets the image's X offset in pixel.
ImageOffsetY
Gets or sets the image's Y offset in pixel.
ImageRotateAngle
Gets or sets the rotation angle of the marker image by degree.
Text
Gets or sets the text displayed on the image.
TextRotateAngle
Gets or sets the rotation angle of the marker text by degree.
TextWidth
Gets or sets the width of text on the marker.
TextWrapping
Gets or sets whether the text wraps when it reaches the edge of its container.
  • Type:TextWrapping
TextOffsetX
Gets or sets the x offset in pixel of text on the marker.
TextOffsetY
Gets or sets the y offset in pixel of text on the marker.
FontStyle
Gets or sets the style applied to the text on the image.
FontColor
Gets or sets the color of the text on the marker.
thinkgeo.mapsuite.silverlightedition.pointmarkerstyle.txt · Last modified: 2017/03/16 21:59 (external edit)
