thinkgeo.mapsuite.silverlightcore.geofont
ThinkGeo.MapSuite.SilverlightCore.GeoFont
This class represents a font that is used to label features on a GeoCanvas.
    • ThinkGeo.MapSuite.SilverlightCore.GeoFont
GeoFont()
  • This constructor creates a GeoFont to be used for labeling features on a GeoCanvas.
  • None
GeoFont(String,Double)
  • None
  • fontName
    • Description:This parameter represents the name of the font to be used.
  • size
    • Description:This parameter represents the size of the font to be used.
GeoFont(String,Double,Boolean)
  • fontName
  • size
  • isItalic
GeoFont(String,Double,DrawingFontStyles)
  • None
  • fontName
  • size
  • style
    • Description:This parameter represents the style of the font to be used.
FontWeight
This property gets the bold property of the font.
IsBold
IsItalic
This property gets the italic property of the font.
IsUnderline
This property gets the underline property of the font.
FontName
This property gets the font name property of the font.
Size
This property gets the font size property of the font.
Style
This property gets the font style property of the font.
FontStretch
Fho=
  • Type:Int64
thinkgeo.mapsuite.silverlightcore.geofont.txt · Last modified: 2017/03/16 21:59 (external edit)
