This class defines the base abstract class for creating MVC control.
Fill an instance based on the input model name according to the input entity string
Convert current object based on mode name to an entity string.
Restores the control information from a persistent object the was saved by the SaveState method.
Does the preparation before sending the Mvc control to the provided HtmlWriter of the ViewContext.
This method notifies the Mvc control to perform any necessary prerendering steps prior to rendering content and save state.
Sends the Mvc control content to a provided HtmlTextWriter object, which wirtes the content to be rendered on the client.
When developing a custom server control, you can override this method to generate conteol for a page.
Saves any necessary information of the Mvc control, which will be used in some other places.
Gets the client script files which will be registered to the page.
Gets the client script blocks which will be registered to the page.
Gets the css files which will be wrote to the client html.
Gets the object which is used for managing, registering the css files used by the control.
