thinkgeo.mapsuite.mvcedition.popupsetting_tpopup_tpopupsetting
ThinkGeo.MapSuite.MvcEdition.PopupSetting‹TPopup,_TPopupSetting›
<!– Class –> A setting for Popup that contains APIs to set properties of PopupSetting using in MVC view.
Protected MethodPopupSetting‹TPopup, TPopupSetting› Initializes a new instance of the PopupSetting class.
Protected MethodPopupSetting‹TPopup, TPopupSetting› TPopup
Public MethodAutoPan Boolean PopupSetting<TPopup,TPopupSetting> Set autoPan for Element property and retun the PopupSetting
Public MethodAutoSize Boolean PopupSetting<TPopup,TPopupSetting> Set autoSize for Element property and retun the PopupSetting
Public MethodGetType Object
Public MethodHasCloseButton Boolean PopupSetting<TPopup,TPopupSetting> Set hasCloseButton for Element property and retun the PopupSetting
Public MethodHeight Int32 PopupSetting<TPopup,TPopupSetting> Set height for Element property and retun the PopupSetting
Public MethodIsVisible Boolean PopupSetting<TPopup,TPopupSetting> Set isVisible for Element property and retun the PopupSetting
Public MethodOffsetXInPixels Int32 PopupSetting<TPopup,TPopupSetting> Set offsetXInPixels for Element property and retun the PopupSetting
Public MethodOffsetYInPixels Int32 PopupSetting<TPopup,TPopupSetting> Set offsetYInPixels for Element property and retun the PopupSetting
Public MethodOpacity Single PopupSetting<TPopup,TPopupSetting> Set opacity for Element property and retun the PopupSetting
Public MethodPosition PointShape PopupSetting<TPopup,TPopupSetting> Set position for Element property and retun the PopupSetting
Public MethodToString Object
Public MethodWidth Int32 PopupSetting<TPopup,TPopupSetting> Set width for Element property and retun the PopupSetting
Protected PropertyElement TPopup MvcElementSettingBase<TPopup,TPopupSetting>
PopupSetting‹TPopup, TPopupSetting›()
Name Type Description
Go Back
PopupSetting‹TPopup, TPopupSetting›(TPopup)
popup TPopup<!– TPopup –>
Go Back
AutoPan(Boolean)
Return Type Description
TPopupSetting<!– TPopupSetting –> The setting of PopupSetting itself
autoPan Boolean<!– System.Boolean –> A autoPan for Element property
<!– ThinkGeo.MapSuite.MvcEdition.PopupSetting{TPopup,TPopupSetting} –> Go Back
AutoSize(Boolean)
autoSize Boolean<!– System.Boolean –> A autoSize for Element property
Int32<!– System.Int32 –>
Type<!– System.Type –>
HasCloseButton(Boolean)
hasCloseButton Boolean<!– System.Boolean –> A hasCloseButton for Element property
Height(Int32)
height Int32<!– System.Int32 –> A height for Element property
IsVisible(Boolean)
isVisible Boolean<!– System.Boolean –> A isVisible for Element property
OffsetXInPixels(Int32)
offsetXInPixels Int32<!– System.Int32 –> A offsetXInPixels for Element property
OffsetYInPixels(Int32)
offsetYInPixels Int32<!– System.Int32 –> A offsetYInPixels for Element property
Opacity(Single)
opacity Single<!– System.Single –> A opacity for Element property
Position(PointShape)
position PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> A position for Element property
String<!– System.String –>
Width(Int32)
width Int32<!– System.Int32 –> A width for Element property
Void<!– System.Void –>
Element
Return Type
TPopup<!– TPopup –>
<!– MvcElementSettingBase{TPopup,TPopupSetting} –> Go Back
thinkgeo.mapsuite.mvcedition.popupsetting_tpopup_tpopupsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
