thinkgeo.mapsuite.mvcedition.classbreakmarkerstylesetting
ThinkGeo.MapSuite.MvcEdition.ClassBreakMarkerStyleSetting
A setting for ClassBreakMarkerStyle that contains APIs to set properties of ClassBreakMarkerStyleSetting using in MVC view.
ClassBreakMarkerStyleSetting(ClassBreakMarkerStyle)
  • Initializes a new instance of the ClassBreakMarkerStyleSetting class.
  • style
    • Description:the ClassBreakMarker Style which will be assigned to Element property
ColumnName(String)
  • Set columnName for Element property and retun the ClassBreakMarkerStyleSetting
  • columnName
    • Description:A columnName for Element property
BreakValueInclusion(BreakValueInclusion)
  • Set breakValueInclusion for Element property and retun the ClassBreakMarkerStyleSetting
  • breakValueInclusion
ClassBreak(MarkerClassBreak)
  • Set classBreak for Element property and retun the ClassBreakMarkerStyleSetting
  • classBreak
Element
thinkgeo.mapsuite.mvcedition.classbreakmarkerstylesetting.txt · Last modified: 2017/03/16 21:59 (external edit)
