thinkgeo.mapsuite.mvcedition.markerclassbreak
ThinkGeo.MapSuite.MvcEdition.MarkerClassBreak
Represents a break with a value and style defined.
    • ThinkGeo.MapSuite.MvcEdition.MarkerClassBreak
MarkerClassBreak()
Initialize a new instance of the MarkerClassBreak class.
If you use this default constructor, then you should set the properties manually.
MarkerClassBreak(Double)
Initialize a new instance of the MarkerClassBreak class using the value specified.
  • value
    • Description:A double value that is compared to the column value to determine whether to apply the specified style to markers.
Value
Gets or sets the break value.
DefaultMarkerStyle
Gets or sets the style that is applied to the markers if the CustomMarkerStyle is not defined.
CustomMarkerStyle
Gets or sets the style that could be any type of MarkerStyle.
The CustomMarkerStyle could be any type of MarkerStyle. This style has a higher priority than the DefaultMarkerStyle. This means that if you defined both DefaultMarkerStyle and CustomMarkerStyle, the CustomMarkerStyle will be used.
thinkgeo.mapsuite.mvcedition.markerclassbreak.txt · Last modified: 2017/03/16 21:59 (external edit)
