thinkgeo.mapsuite.mvcedition.editfeatureoverlay
ThinkGeo.MapSuite.MvcEdition.EditFeatureOverlay
Represents a FeatureOverlay whose features can be added or edited at the client side.
    • ThinkGeo.MapSuite.MvcEdition.Overlay
      • ThinkGeo.MapSuite.MvcEdition.FeatureOverlay
        • ThinkGeo.MapSuite.MvcEdition.EditFeatureOverlay
EditFeatureOverlay(String)
  • id
ToJson()
FromJson(String)
  • jsonString
EhQ=(Page)
  • page
    • Type:Page
  • page
    • Type:Page
TrackMode
Gets a mode of EditFeatureOverlay.
The default mode is TrackMode.None, which means you cannot draw or edit features at the client side. By setting the mode to TrackMode.Point, TrackMode.Line, TrackMode.Polygon etc., you can then add points, lines or polygons to the FeatureOverlay. Setting the mode to TrackMode.Edit, you can edit the shapes at the client side.
EditSettings
Gets an EditSettings object that controls how you can edit the shapes.
The EditSettings object contains four options: IsDraggable, IsReshapable, IsRotatable, IsResizable. By default, all of them are set to true. This means you can drag, reshape, rotate and resize shapes when you are in edit mode. If you set any of these options to false, you prohibit that functionality.
Features
Columns
Style
QueryTools
EditTools
IsVisible
Opacity
  • Type:Single
IsVisibleInOverlaySwitcher
IsBaseOverlay
Id
OnClientAutoRefreshTick
AutoRefreshInterval
  • Type:TimeSpan
Attribution
JsonFeatures
OverlayType
ERQ=
thinkgeo.mapsuite.mvcedition.editfeatureoverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
