This is a helper class that allows you to execute various queries.
GetFeaturesByColumnValue(String,String,ReturningColumnsType)
GetFeaturesByColumnValue(String,String,IEnumerable<String>)
GetFeaturesByColumnValue(String,String)
GetFeaturesContaining(BaseShape,IEnumerable<String>)
GetFeaturesContaining(BaseShape,ReturningColumnsType)
GetFeaturesContaining(Feature,IEnumerable<String>)
GetFeaturesContaining(Feature,ReturningColumnsType)
GetFeaturesCrossing(BaseShape,IEnumerable<String>)
GetFeaturesCrossing(BaseShape,ReturningColumnsType)
GetFeaturesCrossing(Feature,IEnumerable<String>)
GetFeaturesCrossing(Feature,ReturningColumnsType)
GetFeaturesDisjointed(BaseShape,IEnumerable<String>)
GetFeaturesDisjointed(BaseShape,ReturningColumnsType)
GetFeaturesDisjointed(Feature,IEnumerable<String>)
GetFeaturesDisjointed(Feature,ReturningColumnsType)
GetFeaturesIntersecting(BaseShape,IEnumerable<String>)
GetFeaturesIntersecting(BaseShape,ReturningColumnsType)
GetFeaturesIntersecting(Feature,IEnumerable<String>)
GetFeaturesIntersecting(Feature,ReturningColumnsType)
GetFeaturesOverlapping(BaseShape,IEnumerable<String>)
GetFeaturesOverlapping(BaseShape,ReturningColumnsType)
GetFeaturesOverlapping(Feature,IEnumerable<String>)
GetFeaturesOverlapping(Feature,ReturningColumnsType)
GetFeaturesTopologicalEqual(BaseShape,IEnumerable<String>)
GetFeaturesTopologicalEqual(BaseShape,ReturningColumnsType)
GetFeaturesTopologicalEqual(Feature,IEnumerable<String>)
GetFeaturesTopologicalEqual(Feature,ReturningColumnsType)
GetFeaturesTouching(BaseShape,IEnumerable<String>)
GetFeaturesTouching(BaseShape,ReturningColumnsType)
GetFeaturesTouching(Feature,IEnumerable<String>)
GetFeaturesTouching(Feature,ReturningColumnsType)
GetFeaturesWithin(BaseShape,IEnumerable<String>)
GetFeaturesWithin(BaseShape,ReturningColumnsType)
GetFeaturesWithin(Feature,IEnumerable<String>)
GetFeaturesWithin(Feature,ReturningColumnsType)
GetFeaturesOutsideBoundingBox(RectangleShape,IEnumerable<String>)
GetFeaturesOutsideBoundingBox(RectangleShape,ReturningColumnsType)
GetFeaturesInsideBoundingBox(RectangleShape,IEnumerable<String>)
GetFeaturesInsideBoundingBox(RectangleShape,ReturningColumnsType)
GetFeaturesNearestTo(BaseShape,GeographyUnit,Int32,IEnumerable<String>)
GetFeaturesNearestTo(BaseShape,GeographyUnit,Int32,ReturningColumnsType)
GetFeaturesNearestTo(Feature,GeographyUnit,Int32,IEnumerable<String>)
GetFeaturesNearestTo(Feature,GeographyUnit,Int32,ReturningColumnsType)
GetFeaturesNearestTo(Feature,GeographyUnit,Int32,IEnumerable<String>,Double,DistanceUnit)
GetFeaturesNearestTo(BaseShape,GeographyUnit,Int32,IEnumerable<String>,Double,DistanceUnit)
GetFeaturesWithinDistanceOf(BaseShape,GeographyUnit,DistanceUnit,Double,IEnumerable<String>)
GetFeaturesWithinDistanceOf(BaseShape,GeographyUnit,DistanceUnit,Double,ReturningColumnsType)
GetFeaturesWithinDistanceOf(Feature,GeographyUnit,DistanceUnit,Double,IEnumerable<String>)
GetFeaturesWithinDistanceOf(Feature,GeographyUnit,DistanceUnit,Double,ReturningColumnsType)
GetFeatureById(String,IEnumerable<String>)
GetFeatureById(String,ReturningColumnsType)
GetFeaturesByIds(IEnumerable<String>,IEnumerable<String>)
GetFeaturesByIds(IEnumerable<String>,ReturningColumnsType)
GetBoundingBoxesByIds(IEnumerable<String>)
GetAllFeatures(IEnumerable<String>)
This property specifies whether FeatureSource can excute a SQL query or not. If it is false, then it will throw an exception when the following APIs are called: ExecuteScalar, ExecuteNonQuery, ExecuteQuery
The default implementation is false.
