thinkgeo.mapsuite.mvcedition.animationpanmaptoolsetting
ThinkGeo.MapSuite.MvcEdition.AnimationPanMapToolSetting
A setting for ContextMenu that contains APIs to set properties of ContextMenu using in MVC view.
AnimationPanMapToolSetting(AnimationPanMapTool)
  • Initializes a new instance of the AnimationPanMapToolSetting class.
  • mapTool
Delay(Int32)
  • Set delay for Element property and retun the AnimationPanMapToolSetting
  • delay
    • Description:A delay for Element property
OnClientClick(String)
  • Set onClientClick javascript function name for Element property and retun the AnimationPanMapToolSetting
  • onClientClick
    • Description:A onClientClick javascript function name for Element property
Enabled(Boolean)
  • isEnabled
Element
thinkgeo.mapsuite.mvcedition.animationpanmaptoolsetting.txt · Last modified: 2017/03/16 21:59 (external edit)
