thinkgeo.mapsuite.mvcedition.geokeyedcollection_t
ThinkGeo.MapSuite.MvcEdition.GeoKeyedCollection‹T›
<!– Class –> Represents a strong-typed collection that can be accessed by index or by the identifier of an item.
The GeoKeyedCollection class is a hybrid between a collection based on the IList generic interface and a collection based on the IDictionary generic interface. Like collections based on the IList generic interface, KeyedCollection is an indexed list of items. Like collections based on the IDictionary generic interface, KeyedCollection has a key associated with each element.
The types that can be added to the GeoKeyedCollection must implement the IRequireId interface, which forces these types to have an Id property. Thus, we can get the item by identifier from the GeoKeyedCollection. The identifier must be unique and cannot be empty.
Public MethodGeoKeyedCollection‹T› Initializes a new instance of the GeoKeyedCollection class.
Public MethodAdd T Collection<T>
Public MethodClear Collection<T>
Public MethodContains String KeyedCollection<String,T>
Public MethodContains T Collection<T>
Public MethodCopyTo T[], Int32 Collection<T>
Public MethodFromJson String GeoKeyedCollection<T> Load this object from a json string.
Public MethodGetEnumerator Collection<T>
Public MethodGetType Object
Public MethodIndexOf T Collection<T>
Public MethodInsert Int32, T Collection<T>
Public MethodRemove T Collection<T>
Public MethodRemove String KeyedCollection<String,T>
Public MethodRemoveAt Int32 Collection<T>
Public MethodToJson GeoKeyedCollection<T> Returns a JSON string that contains information about all of the items in the collection.
Public MethodToString Object
Protected MethodChangeItemKey T, String KeyedCollection<String,T>
Protected MethodClearItems Collection<T>(overriden)
Protected MethodGetKeyForItem T KeyedCollection<String,T>(overriden) When implemented in a derived class, extracts the key from the specified element.
Protected MethodInsertItem Int32, T Collection<T>(overriden)
Protected MethodRemoveItem Int32 Collection<T>(overriden)
Protected MethodSetItem Int32, T Collection<T>(overriden)
Public PropertyComparer IEqualityComparer<String> KeyedCollection<String,T>
Public PropertyCount Int32 Collection<T>
Public PropertyItem T KeyedCollection<String,T>
Public PropertyItem T Collection<T>
Protected PropertyDictionary IDictionary<String,T> KeyedCollection<String,T>
Protected PropertyItems IList<T> Collection<T>
GeoKeyedCollection‹T›()
Name Type Description
Go Back
Add(T)
Return Type Description
Void<!– System.Void –>
item T<!– T –>
<!– Collection{T} –> Go Back
Clear()
Contains(String)
Boolean<!– System.Boolean –>
key String<!– System.String –>
<!– KeyedCollection{System.String,T} –> Go Back
Contains(T)
item T<!– T –>
CopyTo(T[], Int32)
array T[]<!– Tthinkgeo.mapsuite.mvcedition.geokeyedcollection_t –>
index Int32<!– System.Int32 –>
FromJson(String)
jsonString String<!– System.String –> a json string
<!– ThinkGeo.MapSuite.MvcEdition.GeoKeyedCollection{T} –> Go Back
GetEnumerator()
IEnumerator<T><!– IEnumerator{T} –>
Type<!– System.Type –>
IndexOf(T)
item T<!– T –>
Insert(Int32, T)
item T<!– T –>
Remove(T)
item T<!– T –>
Remove(String)
RemoveAt(Int32)
ToJson()
String<!– System.String –> A string that contains information about all of the items in the collection.
ChangeItemKey(T, String)
item T<!– T –>
newKey String<!– System.String –>
ClearItems()
<!– Collection{T}(overriden) –> Go Back
GetKeyForItem(T)
String<!– System.String –> The key for the specified element.
item T<!– T –> The element from which to extract the key.
<!– KeyedCollection{System.String,T}(overriden) –> Go Back
InsertItem(Int32, T)
item T<!– T –>
RemoveItem(Int32)
SetItem(Int32, T)
item T<!– T –>
Comparer
Return Type
IEqualityComparer<String><!– System.Collections.Generic.IEqualityComparer{System.String} –>
Count
Return Type
Item
Return Type
T<!– T –>
Item
Return Type
T<!– T –>
Dictionary
Return Type
IDictionary<String,T><!– IDictionary{System.String,T} –>
Items
Return Type
IList<T><!– IList{T} –>
thinkgeo.mapsuite.mvcedition.geokeyedcollection_t.txt · Last modified: 2017/03/16 21:59 (external edit)
