thinkgeo.mapsuite.mvcedition.inmemorymarkeroverlaysetting
ThinkGeo.MapSuite.MvcEdition.InMemoryMarkerOverlaySetting
A setting for InMemoryMarkerOverlay that contains APIs to set properties of InMemoryMarkerOverlaySetting using in MVC view.
InMemoryMarkerOverlaySetting(InMemoryMarkerOverlay)
  • Initializes a new instance of the InMemoryMarkerOverlaySetting class.
Columns(Action<Collection<FeatureSourceColumn»)
Feature(Feature)
  • Set feature for Element property and retun the InMemoryMarkerOverlaySetting
  • feature
    • Type:Feature
    • Description:A feature for Element property
Feature(String,Feature)
  • Set feature with specific key for Element property and retun the InMemoryMarkerOverlaySetting
  • key
    • Description:a key string uses for feature
  • feature
    • Type:Feature
FeatureSource(InMemoryFeatureSource)
  • Set featureSource for Element property and retun the InMemoryMarkerOverlaySetting
SuppressingGridSize(Int32)
  • Set suppressingGridSize for Element property and retun the InMemoryMarkerOverlaySetting
  • suppressingGridSize
    • Description:A suppressingGridSize for Element property
ZoomLevelSet(Action<MarkerZoomLevelSet>)
  • Set ZoomLevelSet for Element property according to a method that takes MarkerZoomLevelSet and retun the InMemoryMarkerOverlaySetting
  • zoomLevelSetAction
OnClientClick(String)
  • clientEventHandler
OnClientMarkersRequested(String)
OnClientMarkersRequesting(String)
DataBindTo(String,String)
  • controllerName
  • actionName
ActionTriggers(Action<Collection<ActionTrigger»)
  • triggerActions
IsVisible(Boolean)
  • isVisible
Name(String)
  • name
Opacity(Single)
  • opacity
    • Type:Single
IsVisibleInOverlaySwitcher(Boolean)
  • isVisibleInOverlaySwitcher
IsBaseOverlay(Boolean)
  • isBaseOverlay
Id(String)
  • id
OnClientAutoRefreshTick(String)
  • clientTickFunctionName
AutoRefreshInterval(TimeSpan)
  • timeSpan
    • Type:TimeSpan
Element
thinkgeo.mapsuite.mvcedition.inmemorymarkeroverlaysetting.txt · Last modified: 2017/03/16 21:59 (external edit)
