thinkgeo.mapsuite.mvcedition.valuemarkerstyle
ThinkGeo.MapSuite.MvcEdition.ValueMarkerStyle
This class allows you to match a value with data in the feature to determine how to draw the feature.
    • ThinkGeo.MapSuite.MvcEdition.MarkerStyle
      • ThinkGeo.MapSuite.MvcEdition.ValueMarkerStyle
ValueMarkerStyle()
  • Initialize a new instance of the ValueMarkerStyle class.
ValueMarkerStyle(String)
  • Initialize a new instance of the ValueMarkerStyle class with the columnName specified.
  • columnName
    • Description:The column name used to match with the value specified in the items.
ValueMarkerStyle(String,Collection<MarkerValueItem>)
  • Initialize a new instance of the ValueMarkerStyle class with the columnName and a collection of valueItems specified.
  • columnName
  • valueItems
    • Type:Collection<MarkerValueItem>
    • Description:A collection of valueItems that defines the style applied to markers.
GetMarkers(IEnumerable<Feature>)
  • Returns a collection of markers with a style applied based on the features that are passed in.
  • Type:Collection<Marker>
  • Description:A collection of markers with a style applied based on the features that are passed in.
  • features
    • Type:IEnumerable<Feature>
    • Description:A collection of features used to create the markers.
GetContextMenusCore()
  • Gets a collection of context menus that are associated with the MarkerStyle.
LxU=()
ValueItems
Gets the collection of ValueItems. Each item can have a value to match.
You will want to add MarkerValueItems to this collection. Each item can have its own style and matching string.
ColumnName
Gets or sets the column name used to match with the value specified in the items.
This is the column whose values we will use for matching.
thinkgeo.mapsuite.mvcedition.valuemarkerstyle.txt · Last modified: 2017/03/16 21:59 (external edit)
