This class represents one value in a ValueMarkerStyle.
MarkerValueItem(String,MarkerStyle)
Gets or sets the value that we will use to match with the feature data. If the value matches, we will use the style for this item.
Gets or sets the marker style that will be applied to the markers if the CustomMarkerStyle is not defined.
Gets or sets the style that could be any type of MarkerStyle.
The CustomMarkerStyle could be any type of MarkerStyle. This style has a higher priority than the DefaultMarkerStyle. This means that if you defined both DefaultMarkerStyle and CustomMarkerStyle, the CustomMarkerStyle will be used.
